Inter-VLAN Multicast routing in multiple switch environment over trunk issue at end switch
ghazizadeh
Hi Everone,
i'm not very experienced in Multicast routing , i would appreciate your help in below issue that i'm facing,
here is my setup,
Cisco-6509E with few VLAN , Multicast Stream source are present on VLAN3 ,
Cisco 6509E ---> port channel Trunk (2 SFP 1Gb) ---> 3750G-12S  --> Trunk (single Port) ---> 3750G-24TS
All vlan associated with Trunk is available on all switchs
6509E running  151-2.SY11 advancedipservice
3750G-12S Running 12.2(40) SE , advanceipservice
3750G-24TS Running  12.2(55)SE12 ,  IPSERVICE
multicast route between VLAN in 6509E is working fine,
on 3750G-24TS if i put any port in vlan3, easily can see all the multicast stream that is present in 6509,
but when i cannot see the stream from another VLAN (VLAN 401),
6509E VLANs
interface Port-channel2
 switchport
 switchport trunk allowed vlan 2-4,100
 switchport mode trunk
 switchport nonegotiate
end
interface Vlan3
 ip address x.x.x.x 255.255.255.0
 ip pim sparse-dense-mode
end
3750G-12S
interface Port-channel1
end
interface GigabitEthernet1/0/1
end
interface Vlan3
 ip address x.x.x.x+1 255.255.255.0
end
3750G-24ts
interface GigabitEthernet1/0/25
end
interface GigabitEthernet1/0/3
 switchport access vlan 401
 switchport mode access
end
interface GigabitEthernet1/0/6
 switchport access vlan 3
end
interface Vlan3
 ip address x.x.x.x+2 255.255.255.0
end
interface Vlan401
 ip address y.y.y.y 255.255.255.248
end
an update,
found the problem, for anyone that might encounter this,
issue was that ip routing was not enabled in 3750
Reza Sharifi
There is no vlan 401 on the trunk port.
Also, what device is doing the routing for all vlans 6500 or 3750?
VLAN 401 don't exist on trunk
the reason is that one VLAN3 there are many multicast stream and we want only selected multicast to be on VLAN 401
3750 is doing the routing between vlan3 and vlan401
an update,
Glad you found problem. Sometimes with multicast good to check show ip mroute, the rendezvous point is configured/learnt and for pim adjacencies.
