Inter-VLAN Routing and existing network
danielsormsby
Good afternoon!
Maybe you fine folks can help me - Trying to add another subnet to internal network (to eventually transition to this new subnet). Going to use VLAN's for this, but don't know how to create a VLAN and have it route to the existing network for web access, etc. Any suggestions?
(I've got a Catalyst 3560E That i'd like to use to create the VLAN and do the routing between the new subnet and the old)
Thanks!
17 Replies 17
you are cisco Star. You understand everything =). I'm interested in internal 3750 (two vlans on one switch). I didn't start 7200 yet and 3750 I process, but I'll send config. I'm trying to realise where L3 interface should be for interVLANs.
Thank,
Vlad
Vlad
First have you created vlan 2 at layer 2 ie.
1) run "sh vlan" on the 3750. Do you see entry for vlan 2 as well as vlan 1. If not
3750(config)# vlan 2
3750(config)# name v2
2) Next you need to create routed interfaces for the vlans. On a layer 3 switch you use SVI's (Switched Virtual Interfaces). To create an SVI for vlan 2
3750(config)# int vlan 2
3750(config-if)# ip address 10.20.25.1 255.255.255.0
3750(config-if)# no shut
3) You should already have a L3 SVI for vlan 1. If you but no ip address has been assigned -
3750(config)# int vlan 1
3750(config-if)# ip address 10.20.20.1 255.255.255.0
4) All clients connected to ports in vlan 1 should have an address from 10.20.20.x subnet and their default-gateway should be 10.20.20.1
5) All clients connected to ports in vlan 2 should have an address from 10.20.25.x subnet with default-gateway 10.20.25.1
If you get this working we can then look at your 7200 if you want to add that in later.
Jon
Great! i will config and let you know, you are genuis.
Vlad
