Inter vlan routing create using L3 Switch and router
Rabih.Nasr
I want to create routing between vlans 2,3 and 10 AS
between 2 and 3 though L3 Switch
Between (2,3) And 10 though Router
Please help is can be done I worked on it  last 10 days
If I enabled Routing on L3 switch all vlans will talk to each other because is all directed connected
Please Help
the project is attached too with all comment and devices  sittings
there are numerous issues with your project:
1. The Sophos router needs a default route pointing to 192.168.10.101
2. The L3 switch needs to have 'ip routing' enabled
3. The link between the L3 switch and the router needs to be a trunk
4. Vlan 2 and 3 need to be manually created on the L3 switch
I have added default gateways to all devices. Review the attached, working file.
Thank you very much You're an artist bro
Rabih.Nasr
