inter vlan routing issue
Tony.Reardon
Hi All! I am hoping i've made a rookie mistake in my switch config.... Essentially i have mutliple vlans, if i ssh to my switch i can ping all devices, if im on a vm i can ping all interfaces on my switch (on different vlans to the vm). My issue is with pinging between vlans, essentially it just seems to stop at the switch. The key thing here is i am trying to get from VLAN 164 to 160
Any suggestions what else to check?? heres some of my config
interface Vlan1
no ip address
shutdown
interface Vlan10
no ip address
interface Vlan100
ip address 192.168.100.253 255.255.255.0
interface Vlan160
ip address 192.168.39.4 255.255.255.248
interface Vlan161
no ip address
interface Vlan162
ip address 10.136.170.70 255.255.255.248 secondary
ip address 192.168.39.30 255.255.255.240
interface Vlan163
ip address 192.168.39.62 255.255.255.224
interface Vlan164
ip address 192.168.39.126 255.255.255.192
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.100.254
ip http server
MTPOCASW01# show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.100.254 to network 0.0.0.0
192.168.39.0/24 is variably subnetted, 4 subnets, 4 masks
C 192.168.39.64/26 is directly connected, Vlan164
C 192.168.39.0/29 is directly connected, Vlan160
C 192.168.39.16/28 is directly connected, Vlan162
C 192.168.39.32/27 is directly connected, Vlan163
10.0.0.0/29 is subnetted, 1 subnets
C 10.136.170.64 is directly connected, Vlan162
C 192.168.100.0/24 is directly connected, Vlan100
S* 0.0.0.0/0 [1/0] via 192.168.100.254
5 Replies 5
Mark Malone
so if you ping between vlans .... ping 192.168.39.126  source 192.168.39.4
you get no results at all ?
check running config has command .....ip routing
from the switch is pings fine
MTPOCASW01#ping 192.168.39.126 source 192.168.39.4
Sending 5, 100-byte ICMP Echos to 192.168.39.126, timeout is 2 seconds:
Packet sent with a source address of 192.168.39.4
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Sending 5, 100-byte ICMP Echos to 192.168.39.1, timeout is 2 seconds:
the issue seems to be predominantly going to vlan 160 from vlan 164 as clients on vlan 163 can talk to vlan 164 now that i think about it.
ip routing is enabled
aaa session-id common
switch 1 provision ws-c3750g-48ts
switch 2 provision ws-c3750g-48ts
system mtu routing 1500
vtp mode transparent
ip subnet-zero
ip routing
from a client on vlan 164
Tracing route to 192.168.39.1 over a maximum of 30 hops
1 <1 ms <1 ms <1 ms 192.168.39.126
2 * * * Request timed out.
3 * * * Request timed out.
Ok can any other vlan speak to vlan 160 ?
Make sure the clients in that vlan have correct gateway/subnet , stp is in fwd mode as well not blocking
Havent tried, thats what i need to achieve as it is the management vlan for a pair of ASA's
ports appear to be correctly configured, its not a trunk so stp wouldnt be an issue
interface GigabitEthernet1/0/47
description Link to MTPOCASA01 Mgmt
switchport access vlan 160
switchport mode access
spanning-tree portfast
I wont be able to check the firewall configuration until i get into the DC tomorrow when i will have access to it directly
Deepak Kumar
As I can understand your question, You may make any one of mistake on your Network
1. If you have more than one switch then you have enabled IP routing on any other switch, You check and disable it.
2. Systems gateway is not same as your VLAN IP on your core switch.
3. Any Access-list configured on core switch to deny intervlan routing.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
