Inter vlan routing on Cisco IE4010 series Switchs
19782401a
I'm not shure if and in wich release IE4010 support inter vlan routing
Reading the datasheet document it would seem no
http://www.cisco.com/c/en/us/products/collateral/switches/industrial-ethernet-4010-series-switches/datasheet-c78-737279.html?cachemode=refresh
Have you ever had experience in this scenario? Could you confirm me this?
Gian Luca
Reza Sharifi
I have never used this type of switch but have a look at table-6 in the same link you posted. With LAN base license, layer 3 static routing is supported. So, you should be able to configure inter-vlan routing.
