Inter VLAN Routing over WIFI in Packet Tracer
Domi102831234
Hello guys, i am very new to packet tracer and I have run into an issue.. I have setup a local network with multiple VLANs:
20: MGMT
101-103: 1st to 3rd Floor devices
200: WIFI for Guests
201: WIFI for Employees
the WIFI is managed by a WLC and everything is connected to a layer 3 switch. I have enabled inter vlan routing on that switch so that the 3 floors can communicate with each other, which works fine. However, the WIFI devices can't seem to reach any devices from different vlans, even though they should be configured exactly the same. They can reach other WIFI devices in the same SSID/VLAN though. The layer 3 switch has ip addresses for each interface, the wifi devices have those ips as their gateways.
Spoiler
Switch#show ip route
Gateway of last resort is not set
C 192.168.20.0/24 is directly connected, Vlan20
C 192.168.101.0/24 is directly connected, Vlan101
C 192.168.102.0/24 is directly connected, Vlan102
C 192.168.103.0/24 is directly connected, Vlan103
C 192.168.200.0/24 is directly connected, Vlan200
I saw an option for ACLs in the WLC, however they are all greyed out.. Is it simply not possible to have the wifi devices access other vlans in PT? Or am I missing something?
Domi102831234
Edit: I figured it out, I forgot to configure the VLANs for WIFI on the floor switches, where the APs are connected..
Domi102831234
