Inter-vlan routing problems
Fabio Francisco
Level 5
Level 5
Hi all,
I setting up a new network for my company. It's a small network for 70 people.
For some reason inter-vlan routing is not behaving correctly. sometimes you can ping devices in other subnets other times you cannot. I checked memory, CPU, TCAM and they all seems all right.
I wonder if I made a mistake in the config. Please see below
aaa session-id common
system mtu routing 1500
ip subnet-zero
ip routing
no ip domain-lookup
ip domain-name xxxxxxx.com.au
ip dhcp snooping
no file verify auto
spanning-tree mode rapid-pvst
spanning-tree vlan 1,40,50,60 priority 24576
vlan internal allocation policy ascending
interface Loopback1
ip address 1.1.1.1 255.255.255.255
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Vlan1
ip address 172.16.1.31 255.255.255.0
ip helper-address 172.16.1.250
interface Vlan40
ip address 172.16.40.1 255.255.255.0
ip helper-address 172.16.1.251
interface Vlan50
ip address 172.16.50.1 255.255.255.0
interface Vlan60
ip address 172.16.60.1 255.255.255.0
router eigrp 1
network 172.16.1.0 0.0.0.255
network 172.16.40.0 0.0.0.255
network 172.16.60.0 0.0.0.255
auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.1.42
ip http server
Any help would be very appreciated.
Fabio
10 Accepted Solutions
Richard Burts
Fabio
There are some things that you have not told us about your network and if we knew them we might be able to give better advice. For example in the config that you posted all the ports are in the default VLAN 1. But the config contains VLANs 40, 50, 60. What are these VLANs and where are they connected?
Also this config has configured router eigrp. Is there some connected device that is running eigrp?
In addition to explaining the details that I have identified it might be helpful if you would post the output of show ip route.
Rick
Rick
martin_knorre
Level 4
Level 4
Hi Fabio,
can you show me a "show ip route" ???
without it I can't say anything reliable 😉
rgds Martin
Can you post a diagram of your topology as well as explain what is not working more precisely.
How come you have no eigrp routes? is it normal?
Regards.
Alain.
yes its normal, because he is on his layer 3 switch
with the local configured VLAN Interfaces so the vlan Interfaces for VLAN 20,30 etc is local connected.
Can you see the eigrp routes on the other neighbours?
have you configured to trunk all vlans to the other L2 switches?
Have you already the native vlan 1 active?
Rgds Martin
Hi Martin,
I know that but  just wanted to know why  we didn't see other eigrp routes.
Regards.
Alain.
Fabio
Not having the interfaces configured as trunk would impact the ability to forward traffic to the access switches. As access ports the only vlan and subnet that the switch can get to is vlan 1 and subnet 172.16.1.0. The configured vlan interfaces tell the switch that other vlans and other subnets exist, but the switch does not know where they were or how to forward to them. It would have no ability to tag frame for vlan 40 or 50 or 60 and forward them.
Rick
Rick
Fabio
If it sometimes works and sometimes does not work then it seems to indicate that something in the network is fluctuating. I wonder if it could be a spanning tree issue? Are the access switches connected to both core01 and core02 switches? Is it possible that there is a loop in the network?
Perhaps you could post the output of show cdp neighbor from both core switches? It might also be helpful if you post the output of show interface trunk from both switches.
Rick
Rick
Fabio,
     I was just reading your post here, would you be able to post your "sh int trunk"??? and also your "sh cdp neighbors"?? I want to check, if possible, if your vlans are going inside the trunk properly..as well which is your native vlan. Ohhh I almost forgot...also there is one more "sh int swi".
regards,
Thiago
Do you have vlans 30, 40, and 50  configured??if so, do you have switchports attached to
those vlans??I mean, whatever servers / end-users pcs connected to these switchports??
Thiago Henriques
Fabio
I am glad that you got it working. I guess that this demonstrates that sometimes, especially with very strange problems, a reboot is a way to fix a problem and get things working.
Thanks for posting back to the forum indicating that you got it to work and what you did to get it to work. It makes the forum more useful when people can read about a problem and can also read what was done that resolved the problem.
Rick
Rick
17 Replies 17
Richard Burts
Fabio
Rick
Rick
Hi Rick,
Thanks for your reply.
1) ip route is:
Gateway of last resort is 172.16.1.42 to network 0.0.0.0
     1.0.0.0/32 is subnetted, 1 subnets
C       1.1.1.1 is directly connected, Loopback1
     172.16.0.0/24 is subnetted, 4 subnets
C       172.16.60.0 is directly connected, Vlan60
C       172.16.50.0 is directly connected, Vlan50
C       172.16.40.0 is directly connected, Vlan40
C       172.16.1.0 is directly connected, Vlan1
S*   0.0.0.0/0 [1/0] via 172.16.1.42
2) VLANS 40, 50 AND 60 are set on 3 2960's and 2 2950's
3) yes there 2 more devices currently running eigrp the other 3560 and a router ip add 172.16.1 42
BTW I just noticed that I set the interfaces to trunk only on the access switches....  I just fixed it now on the 3560's:
switchport mode trunk
I hope this wouldn't cause any problem to the inter-vlan routing.. I cannot se how anyway...
Thanks in advance.
Fabio
Fabio
Rick
Rick
martin_knorre
Level 4
Level 4
Hi Fabio,
rgds Martin
Regards.
Alain.
Rgds Martin
Hi Martin,
Regards.
Alain.
yes
CORE01-  sh ip eigrp neighbours
IP-EIGRP neighbors for process 1
H   Address                 Interface       Hold Uptime   SRTT   RTO  Q  Seq Typ
e
                                            (sec)         (ms)       Cnt Num
4   172.16.1.42             Vl1               14 00:04:47    1  3000  0  23
3   172.16.1.33             Vl1               14 00:04:49    1  4500  0  50
2   172.16.60.3             Vl60              10 00:07:10    1   200  0  47
1   172.16.50.3             Vl50              13 00:07:21  554  3324  0  49
0   172.16.40.3             Vl40              11 00:07:32  344  2064  0  48
CORE02 - sh ip ei neighbors
e
                                            (sec)         (ms)       Cnt Num
5   172.16.1.32             Vl1               12 00:06:54  705  4230  0  55
3   172.16.60.2             Vl60              10 00:09:20 1530  5000  0  54
2   172.16.50.2             Vl50              13 00:09:31    1   200  0  52
0   172.16.40.2             Vl40              14 00:09:42    1   200  0  53
1   172.16.1.42             Vl1               12 00:30:39    1   200  0  22
yes
As far as I know vlan 1 is the native vlan by default.... Is it what you were after?
Thank you very much for your reply...
Cheers,
Fabio
Fabio Francisco
Level 5
Level 5
Hi Guys,
Thank you very much for getting back to me. Below is the sh ip route command from the three devices running EIGRP
Router - sh ip route:
Gateway of last resort is 220.233.x.x to network 0.0.0.0
D       172.16.60.0 [90/28416] via 172.16.1.31, 00:01:53, FastEthernet1/0
                    [90/28416] via 172.16.1.33, 00:01:53, FastEthernet1/0
D       172.16.50.0 [90/28416] via 172.16.1.33, 00:00:43, FastEthernet1/0
                    [90/28416] via 172.16.1.31, 00:00:43, FastEthernet1/0
D       172.16.40.0 [90/28416] via 172.16.1.31, 00:02:05, FastEthernet1/0
                    [90/28416] via 172.16.1.33, 00:02:05, FastEthernet1/0
C       172.16.1.0 is directly connected, FastEthernet1/0
     220.233.x.x/30 is subnetted, 1 subnets
C       220.233.x.x is directly connected, FastEthernet0/0
S*   0.0.0.0/0 [1/0] via 220.233.x.x
SW core 01 - sh ip route:
SW core 01 - running config
Building configuration...
Current configuration : 2834 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
aaa new-model
aaa authentication login Users_Database local
ip subnet-zero
ip routing
no ip domain-lookup
ip dhcp snooping
no file verify auto
interface Loopback1
interface Vlan1
interface Vlan40
interface Vlan50
interface Vlan60
router eigrp 1
network 172.16.50.0 0.0.0.255
no auto-summary
ip classless
ip http server
radius-server source-ports 1645-1646
control-plane
line con 0
exec-timeout 60 0
logging synchronous
line vty 0 4
exec-timeout 60 0
logging synchronous
login authentication Users_Database
line vty 5 15
exec-timeout 60 0
logging synchronous
ntp server 172.16.1.59
end
SW core 02 - sh ip route
The thing that is doing my head in is the fact that it works for a minute and then it stops working again... eq if I am in VLAN 40 and have an ip 172.16.40.101 I can ping VLAN's 1 gateway 172.16.1.31 which tells me that traffic is being routed by the switch. Other times I cannot even ping 172.16.1.31.
The same applies with devices in VLAN 1 and 40 (I'm only testing those two VLANs for the moment).
Please help.
Fabio
Rick
Rick
Hi Rick,
Thank you very much for your reply. I have set all switches with RSTP. I just turned CORE02 off and now I can assure you that there isn't any loops....
CORE01 - sh cdp neig
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
NTCACC01         Gig 0/2           120           S I      WS-C2960- Gig 0/4
NTCACC02         Gig 0/1           120           S I      WS-C2960- Gig 0/4
NTCACC03         Gig 0/22          120           S I      WS-C2960- Gig 0/4
NTCROUTER01      Gig 0/24          127            R       3640      Fas 1/0
CORE01 - sh interfaces trunk
Port        Mode         Encapsulation  Status        Native vlan
Gi0/1       on           802.1q         trunking      1
Gi0/2       on           802.1q         trunking      1
Gi0/22      on           802.1q         trunking      1
Gi0/24      on           802.1q         trunking      1
Port        Vlans allowed on trunk
Gi0/1       1-4094
Gi0/2       1-4094
Gi0/22      1-4094
Gi0/24      1-4094
Port        Vlans allowed and active in management domain
Gi0/1       1,40,50,60
Gi0/2       1,40,50,60
Gi0/22      1,40,50,60
Gi0/24      1,40,50,60
Port        Vlans in spanning tree forwarding state and not pruned
Gi0/1       1,40,50,60
Gi0/2       1,40,50,60
Gi0/22      1,40,50,60
Gi0/24      1,40,50,60
CORE01 - sh ver
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(35)SE5, RELEAS
E SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 18:15 by nachen
Image text-base: 0x00003000, data-base: 0x01100000
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEE4, RELEASE SOFTWA
RE (fc1)
NTCCORE01 uptime is 10 minutes
System image file is "flash:c3560-ipbase-mz.122-35.SE5/c3560-ipbase-mz.122-35.SE
5.bin"
cisco WS-C3560G-24TS (PowerPC405) processor (revision D0) with 122880K/8184K byt
es of memory.
Processor board ID FOC1238W1CP
Last reset from power-on
4 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
--More--
I'll keep CORE02 down to keep things simple for the moment.
Could be something wrong with the IOS image?
I'm right now on VLAN 40. I can ping VLAN 1 gateway 172.16.1.31
C:\Users\fabiof>ping 172.16.1.31
Pinging 172.16.1.31 with 32 bytes of data:
Reply from 172.16.1.31: bytes=32 time=18ms TTL=255
Reply from 172.16.1.31: bytes=32 time=1ms TTL=255
However I cannot ping a server IP address 172.16.1.200 from my machine. it times out...
But now from CORE01 it works
NTCCORE01#ping 172.16.1.200
Sending 5, 100-byte ICMP Echos to 172.16.1.200, timeout is 2 seconds:
Thanks in advace for your help!
Cheers,
Fabio
Fabio,
regards,
Thiago
Hi Thiago,
Thank you very much for your reply. I posted above sh cdp and sh int trunk.
I'm not too sure if thisis the command that you were after. the Gig 0/1 int connect to one of the access switches.
NTCCORE01#sh interfaces gigabitEthernet 0/1 swi
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Cheers,
Fabio
Thiago Henriques
