Inter Vlan Routing with DHCP
shane.kearney
Hi Guys and Girls, I am sitting here in the early hours of the night in Ireland trying to figure out if it possible to complete my simulator network. this is the low down
1 network lots of clients; but all in different VLANs. I have clients in VLAN 120 and clients in VLAN 30 both connected to the same switch and more clients in VLAN 120 and 30 connected to another switch and even more clients in VLAN 120 and 30 connected to another switch... the 3 switches are connected to a L3 switch and a dhcp server is connected to the L3 switch, how do i get intervlan routing working or am I over thinking this big time... I am up very late
You can do it both ways:
On the router:
ip dhcp pool VLAN1
network 10.20.0.0 255.255.255.0
default-gateway 10.20.0.1
ip dhcp pool VLAN2
network 10.20.1.0 255.255.255.0
default-gateway 10.20.1.1
int VLAN1
ip address 10.20.0.1 255.255.255.0
int vlan2
ip address 10.20.1.1 255.255.255.0
The router will automatically find the pool that belongs to the SVI.
On an external DHCP server, you would configure multiple pools that correlate with the SVI ip subnet:
Subnet 10.20.1.0
Subnet 10.20.2.0
Subnet 10.20.3.0
On the router:
int Vlan1
ip helper-address 10.20.5.50 <--your dhcp server address
int vlan2
ip address 10.20.2.1 255.255.255.0
int vlan3
ip address 10.20.3.1 255.255.255.0
The router will redirect your request with the appropriate subnet to the dhcp server.
Oh, and you don't need to do both router dhcp pools and server dhcp pools. You only need one or the other. :-)
John
HTH, John *** Please rate all useful posts ***
6 Replies 6
ohassairi
Level 5
Level 5
of course this is possible. you just create interfaces VLAN 120 and VLAN30 in your layer3 switch. you give them IP addresses (these will be the gateway of your PCs).
of course cascades should be configured as trunk between your access switches and the L3 switch.
then create a new vlan (in L3 sw) for your dhcp server. let say vlan10. give it an ip address and add one port member of vlan10.
connect your server.
under interface vlan 120 add the command:ip helper-address IP1. where IP1 is the IP of your dhcp server.
do the same for vlan30.
hope this will help and you are not very tired. sleeping could be a solution some times as a reset for a router :-)
This is my update...
4 VLAN's 4 reg switches 1 L3 switch 1 router
Each VLAN in different subnets all 50.x.x.x range
Inter- VLAN routing works fine
I want a DHCP pool that will assign IP addresses to all subnets; I know I will need more than 1 pool for this.
I don't know where to configure this....on another router...on the L3 switch.... do I need to set up multiple DHCP servers if not; and I set up multiple DHCP pools on say 1 router then how do I bind that pool to a particular VLAN...
Please help me
On the router:
ip dhcp pool VLAN1
ip dhcp pool VLAN2
int VLAN1
int vlan2
Subnet 10.20.1.0
Subnet 10.20.2.0
Subnet 10.20.3.0
On the router:
int Vlan1
int vlan2
int vlan3
John
int vlan3
what happened when i change vlan 3 ip address 10.20.3.1 255.255.255.0
with same ip helper-address 10.20.5.50 it works for me
can we perform inter vlan routing with dhcp without creating sub-interfaces on router where dhcp is running.
plz reply fast???
Very usefull, thank u.
