04-05-2011 04:35 PM - edited 03-06-2019 04:27 PM
Good evening,
I am currently studying for my CCNA and have been attempting the inter VLAN routing practicle using 'Router on a stick'. I know this is meant to be a fairly straight forward exercise but I can't see where I'm going wrong and was wondering if some one could point me in the right direction.
I cannot get the hosts in the different VLANs to ping each other. This is how I am set up:
I have a Cisco 2950 switch running IOS 12.1, a Cisco 1800 router running IOS 12.4 and 2 laptops, one running vista and one running windows 7.
I have created the following VLANs:
VLAN Name Status Ports
1 default active Fa0/1, Fa0/4, Fa0/5, Fa0/6
Fa0/7, Fa0/8, Fa0/9, Fa0/10
Fa0/11, Fa0/12, Fa0/13, Fa0/14
Fa0/15, Fa0/16, Fa0/17, Fa0/18
Fa0/19, Fa0/20, Fa0/21, Fa0/22
Fa0/23, Fa0/24, Gi0/1, Gi0/2
2 Andrew active Fa0/2
3 Marc active Fa0/3
VLAN 1 has been configured with the IP 10.142.5.129 255.255.255.192 default gateway 10.142.5.1
I have the Vista laptop patched into fa0/2 and the windows 7 laptop in fa0/3. The switch port configs are as follows:
interface FastEthernet0/2
description LAN connection to Andrew PC
switchport access vlan 2
no ip address
spanning-tree portfast
interface FastEthernet0/3
description LAN connection to John PC
switchport access vlan 3
no ip address
The IP addresses of the laptops are as follows:
Vista (VLAN 2) - 10.142.5.6 255.255.255.192 default gateway 10.142.5.1
7 (VLAN 3) - 10.142.5.66 255.255.255.192 default gateway 10.142.5.65
I have configured a trunk on fa0/1 of the switch to fa 0 on the router, the sw port config as follows:
interface FastEthernet0/1
description trunk connection to R1
switchport mode trunk
no ip address
Fa0 on the router has been configured with 2 subinterfaces as follows:
description Beechfield LAN A
no ip address
speed 100
full-duplex
interface FastEthernet0.2
encapsulation dot1Q 2
ip address 10.142.5.1 255.255.255.192
no snmp trap link-status
interface FastEthernet0.3
encapsulation dot1Q 3
ip address 10.142.5.65 255.255.255.192
I can successfully ping both subinterfaces from both hosts but yet can't ping one host from the other. Can anyone point out what I am missing?
Any help would be greatly appreciated.
Andy
Solved! Go to Solution.
04-05-2011 05:11 PM
Please disable the firewall on your clients.04-05-2011 04:54 PM
Hi Andy,
What does the output of "sh int fa0/1 switchport" look like?
Cheers,
Chris
04-07-2011 02:17 PM
Hi Chris,
Thanks very much for your response, very much appreciated! The problem I was experiencing was just a windows firewall issue.
Thanks again
Andy
04-05-2011 05:11 PM
Please disable the firewall on your clients.04-07-2011 02:20 PM
Hi Leolaohoo,
Thanks for your response, you were bang on the money!
Cheers
Andy
