Inter vlan routing
robertson.mike
My core switch is a 6509-e and my IDF closets have 3750's.
I have a couple of vlans currently setup, that can communicate with each other.
VTP is setup Client/Server where as my core is Server, all IDF's are Client.
What i'm trying to do is create an isolated VLAN.  I want to setup a DHCP scope and use helper address.  When i plug in a client to that VLAN, i want it to get an IP, but not have any other network access.
Is this possible to do without switching to Transparent mode?
If not - what reprocussions will i see by switching to transparent mode?
9 Replies 9
rizwanr74
Level 7
Level 7
Hi Mike,
You can use VACL to isolating a vlan from rest of the networks, please read this thread below.
https://supportforums.cisco.com/message/3581631#3581631
Please rate helpful post.
thanks
Rizwan Rafeek
rizwanr74
Level 7
Level 7
thanks
Why not set up a private vlan? Although you would need to change that particular switch to transparent mode, since vtp can't pass private vlan info, it would be the most secure setup. As previously mentioned, vacl would work too but not as secure.
Tagir Temirgaliyev
above it is written correctly and there is one more simple way
to create an isolated VLAN just do not create default gateway.
setup a DHCP scope whithout default gateway or use wrong default gateway.
and so when you plug in a client to that VLAN,  it to get an IP, but not have any other network access.
Also you can create VTP pruning to protect the isloated vlan information to be shared to the other vlans and vice versa....
rizwanr74
Level 7
Level 7
Hi Mike,
Please rate helpful post, if this has been resolved already.
thanks.
Hari Haran S M
Hi Mike,
You can keep the switch as VTP client and achieve this. Follow the below steps,
=> Configure a access list allowing IP's that the isolated VLAN has to access [DHCP server]
=> Deny all other traffic in the access list
=> Apply the Access list in SVI interface of that VLAN
Using the above you should be able to isolate the VLAN from access the other vlan's.
If you would like to block traffic between hosts in the same vlan then you can use VLAN access Map [VACL]
Hope this helps!!!
Sandeep Choudhary
Hi Mike,
Hope this is yor questions answer:
I am using like this:
Core switch config:
service password-encryption
hostname nnXCI001
no logging console
enable secret 5 xxxxxxxxxxxxxxxxxxxxx
username xxxxx
switch 1 provision ws-c3750g-12s
switch 2 provision ws-c3750v2-48ts
system mtu routing 1500
vtp domain location
vtp mode transparent
ip subnet-zero
ip routing
no ip domain-lookup
ip domain-name xxx.xxxx.com
no ip dhcp use vrf connected
ip dhcp snooping vlan 21-26
ip dhcp snooping
spanning-tree mode mst
spanning-tree etherchannel guard misconfig
spanning-tree uplinkfast
spanning-tree mst configuration
name location
revision 1
instance 1 vlan 1, 21-26,
spanning-tree mst 0-1 priority 24576
spanning-tree vlan 1,21-26 priority 24576
vlan internal allocation policy ascending
vlan 7
name FW-Transfer
vlan 21
name Data_VLAN21
vlan 22
name Data_VLAN22
vlan 23
name Data_VLAN23
vlan 24
name Data_VLAN24
vlan 25
name Data_VLAN25
vlan 26
name Data_VLAN26
ip tftp source-interface Vlan1
ip ssh version 2
all Ports
Int fa0/1
Description **** DHCP 10.xx.21.1 server****
ip dhcp snooping trst
interface Vlan1
ip address 10.xx.1.1 255.255.255.0
interface Vlan7
ip address 10.xx.7.1 255.255.255.0
interface Vlan21
ip address 10.xx.21.254 255.255.255.0
interface Vlan22
ip address 10.xx.22.254 255.255.255.0
ip helper-address 10.XX.21.1
interface Vlan23
ip address 10.xx.23.254 255.255.255.0
interface Vlan24
ip address 10.xx.24.254 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.xx.7.254
no ip http server
ip http authentication local
ip http secure-server
end
this is just the example.
May be u can use like this.
Please rate if it helps.
