inter vlan routing
sahar.co67
Hi my friend.
What is the method's of inter vlan routing?
Tnx
7 Replies 7
Leo Laohoo
Depends on what you have.
Do you have a Layer 3 switch or a router?
How To Configure InterVLAN Routing on Layer 3 Switches
Configuring InterVLAN Routing
No i just want name of this method! Both with mls and router.
AhmedSonba
Level 5
Level 5
Hello Sahar,
If you will use the router for the inter vlan routing than its named as router on a stick, while if you used a Layer three switch than its called Layer 3 switch-Inter VLAN Routing
Hope it will help
Ahmed Sonba
Tnx i get my answer!!!
one question i have. What is the other methods of inter vlan routing except with router and mls!!?
The last method is to configure each router port ( as a layer 3 port) connecting to each switch port as an access port.
this is the less scalable method of the 3.
Example
PC1---SWITCH---ACCESS_PORT_VLAN_20---ROUTER-----ACCESS_PORT_VLAN_10SWITCH----PC2
If you do not have any other question, please mark the question as answered,
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
singhaam007
Level 9
Level 9
HI Sarah,
Its really depends how you want to configure inter vlan routing and what you want to use.
http://www.firewall.cx/networking-topics/vlan-networks/222-intervlan-routing.html
Please check this link and its explaining all the different methods you can use.
thanks
Sandeep Choudhary
Hi Sahar,
you have to configure subinterfaces for encapsulation.
see the example:If you are configuring on Router
Create sub-interfaces, set 802.1Q trunking protocol and ip address on each sub-interface
Router(config)#interface f0/0
Router(config-if)#no shutdown
(Note: The main interface f0/0 doesn’t need an IP address but it must be turned on)
Router(config)#interface f0/0.0
Router(config-subif)#encapsulation dot1q 15
Router(config-subif)#ip address 192.168.15.1 255.255.255.0
Router(config-subif)#interface f0/0.1
Router(config-subif)#encapsulation dot11 20
Router(config-subif)#ip address 192.168.20.1 255.255.255.0
(Note: In the “encapsulation dot1q 15″ command, 15 is the VLAN ID this interface operates in)
Configure VLAN
Switch(config)#vlan 15
Switch(config-vlan)#name SALES
Switch(config-vlan)#vlan 20
Switch(config-vlan)#name TECH
Set ports to access mode & assign ports to VLAN
Switch(config)#interface range fa0/1
Switch(config-if)#no shutdown
Switch(config-if)# switchport mode access
Switch(config-if)# switchport access vlan 15
Switch(config-if)#interface range fa0/3
Switch(config-if)#switchport mode access
Switch(config-if)# switchport access vlan 20
see the example:If you are configuring on layer 3 switch:
ip routing
interface FastEthernet0/1
switchport access vlan 10
interface FastEthernet0/3
interface Vlan15
interface Vlan20
And on hosts just assign IP addresses and default gateways (to the corresponding interface VLANs) -> hosts in different VLANs can communicate.
please rate if it helps.
