Cisco Catalyst 3560 G POE 48
paul dungey
        Good morning,
Im trying to access the switch to reset the password to factory defaults (please see switch output Astrix has removed customer identifying information for security purposes.) Each time I reboot the switch and try and access the password recover mode this same output below starts and im still not able to access the recovery area of the switch
cisco WS-C3560G-48PS (PowerPC405) processor (revision F0) with 122880K/8184K bytes of memory.
Processor board ID FOC1133Y28Q
Last reset from power-on
1 Virtual Ethernet interface
52 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:1D:71:48:16:80
Motherboard assembly number     : 73-10212-04
Power supply part number        : 341-0108-03
Motherboard serial number       : FOC11325JRX
Power supply serial number      : DCA1130A0EN
Model revision number           : F0
Motherboard revision number     : B0
Model number                    : WS-C3560G-48PS-S
System serial number            : FOC1133Y28Q
Top Assembly Part Number        : 800-26845-01
Top Assembly Revision Number    : B0
Version ID                      : V05
CLEI Code Number                : CNMWW00ARC
Hardware Board Revision Number  : 0x09
Switch   Ports  Model              SW Version              SW Image
*    1   52     WS-C3560G-48PS     12.2(35)SE5             C3560-IPBASE-M
Press RETURN to get started!
00:02:28: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
00:02:29: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
00:02:32: %SYS-5-CONFIG_I: Configured from memory by console
00:02:33: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan22, changed state to down
00:02:33: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 18:15 by ****************
                           NOTICE TO USERS
This system is the property of ****************************************.
It is only for users authorised by *************************** . If you are not an
authorised user then disconnect immediately. Unauthorised or improper use of
this system may result in administrative disciplinary action and civil and
criminal penalties. Users (authorised or unauthorised) have no explicit or
implicit expectation of privacy. Any or all uses of this system may be
subject to one or more of the following actions: interception, monitoring,
recording, auditing, inspection and disclosing to security personnel and law
enforcement personnel, as well as authorized officials of other agencies,
both domestic and foreign. By using this system, the user consents to these
actions. By accessing this system you indicate your awareness of and consent
to these terms and conditions of use. Discontinue access immediately if you
do not agree to the conditions stated in this notice.
This system name is *******************
User Access Verification
Password:
Paul Dungey
Sandeep Choudhary
Hi  Paul,
just reset the switch :
Physically opened the switch,
- Hold the mode button  (directly on the mini board) and reboot the unit – Release it when the light on top 1x went off
- Accept the message to reset to factory default
- type boot and voila problem fixed.
or
Erase the startup configuration with the erase startup-config command
Delete the vlan.dat file
Reload
may be it helps.
Please rate if it helps.
