Interconnection
arzarcomparex
Community Member
Hi all,
I have a Radio VHF system that I have to monitor. The 192.168.X.X network, works in Broadcast, so only can see the network 10.20.0.X and not the rest.
From my corporate network I have to be able to see all the trafic, What can I do?
Thanks in advance.
sunugopal
Frequent Visitor
Frequent Visitor
I assume all switches shown in your diagram are Layer2 switches and TRBNET server is your gateway for Corp network.
1)     Configure Default gateway on TRBNET Server as 10.20.0.2 (ROUTER1 ip address).
2)
a)  Login to ROUTER1 and ensure that there is a route exists for your Corp network 10.210.50.x /24 reachable  via      10.20.0.99 (TRBNET server ip address). If not, please add the route.
b)  Add a route to 192.168.1.0/24 via next hop 10.20.0.3
3)  Login to ROUTER2 add a route to network 10.210.50.0 /24 via next hop 10.20.0.2 (ROUTER1 ip address).
If you want to manage/monitor L2 switches you need to configure default gateways on them.
   For Switch 1 & Switch 2, configure 192.168.0.1 (ROUTER 1 ip address) as default gateway.
   For Switch on right side, configre 192.168.1.1 (ROUTER 2 ip address) as default gateway.
Hope this helps......
