Interface Bonding on 2911
michaelnilsson1
I have a cisco router 2911 with configured subinterfaces to allow for Inter-VLAN routing. My goal is to setup bonding (bundle, port-channel) on GE0/0 and GE0/1 to allow for redundancy in case of cable failure.
Because i set the channel-group on both GE0/0 and GE0/1 i would assume these interfaces are now bundled.
I do however need the encapsulation dot1Q and have 10.10.10.1 as default GW at all times. So I cant set on GE0/1.10
ip address 10.10.10.4 255.255.255.0
% 10.10.10.4 overlaps with GigabitEthernet 0/0.10
So after reading up on port-channel and dot1Q you can actually do
interface port-channel 1.10
On some routers, but not the 2911
Is there any way for me to get this working using port-channel or any other methods?
Heres my configuration
interface Port-Channel 1
   no ip address
interface GigabitEthernet 0/0
   no ip address
   channel-group 1
   duplex auto
   speed auto
interface GigabitEthernet 0/0.10
   encapsulation dot1Q 10
   standby version 2
   standby 1 ip 10.10.10.1
   standby 1 priority 20
   standby 1 preempt
   standby 1 track GigabitEthernet 0/2
interface GigabitEthernet 0/0.20
   encapsulation dot1Q 20
   ip address 10.10.20.4 255.255.255.0
   standby version 2
   standby 1 ip 10.10.20.1
   standby 1 preempt
interface GigabitEthernet 0/1
   no ip address
   channel-group 1
   duplex auto
   speed auto
interface GigabitEthernet 0/1.10
#  doesnt work
#   ip address 10.10.10.4 255.255.255.0
#   standby version 2
#   standby 1 ip 10.10.10.1
#   standby 1 priority 20
#   standby 1 preempt
#   standby 1 track GigabitEthernet 0/2
Philip D'Ath
I just tested this on a 2911 running 15.4(3)M4 and it worked perfectly.  Config below.
When using port-channels layer 3 configuration should only be done on the "Port-Channel" interface.  You must remove any layer 3 configuration from the physical interfaces, and there should be no sub-interfaces configured (on the physical interfaces).
interface Port-channel1.10
Philip D'Ath
ps. I guess it is possible this is a "licenced feature".  The 2911 I tested this on has an AppX licence (used to be called a "data" licence).  If you upgrade to 15.4(3)M4 and it doesn't work - that means you need the extra licence.
Yes you are right!
Silly of me to try this in Packet Tracer before trying on the router itself.
Yes, interface port-channel1.10 worked without additional licenses.
Thank you
