Interface Configuration
henokk601
Hello Everyone I have 4500-x with all 10g interfaces and ASR1001-X with 1g interface and i have connectivity between them so how can i communicate these two different interfaces so that there will be communication between them any help please?
Mark Malone
hi
if they don't auto negotiate , you may have to hard set them each side to bring them up/up , what sfps are you using glc-sx-mm
interface x/x
speed 1000
no negotiation auto
Julio E. Moisa
Have you tried using speed auto? Also verify if you are using the same model of SFP, I remember that some 10G SFP slots support SFP of 1G.
Regards.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Joseph W. Doherty
Fiber?
If so, if you connect a gig SFP to 4500-x and to ASR1k, both sides should run at gig.
