interface counter show zero
Hi friends,
l have to following question, we have this interface up, but interface counters are showing 0 input / output , why is that ?
GigabitEthernet5/0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 4c71.0d80.7f03 (bia 4c71.0d80.7f03)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is on, output flow-control is unsupported
Last input never, output 00:00:01, output hang never
Last clearing of "show interface" counters 3d20h
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Contact Cisco TAC and get this behaviour analyzed.
I've used 16.12.2 and I don't see this sort of behaviour.
11 Replies 11
Mark Elsen
 - Is there any traffic on the interface ?
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
any other ideas ? we are planning a reboot as well
Quentin Gabrel
Frequent Visitor
Frequent Visitor
As mentioned by marce1000, there may be no traffic.
Have you tried on another port ?
Moreover, are you sure that the port of the other equipment is up ? Maybe a negotiation issue... (Up on your side, but down on the other side)
Leo Laohoo
Post the complete output to the command
sh controller ether Gi 5/0/1
Giuseppe Larosa
Hello @BorislavPenchev0962 ,
post a show version this looks like to be a stack with at least 5 members.
I have seen this "cosmetic" issue in the past on some platforms and IOS XE versions.
Follow also the @Leo Laohoo 's suggestion that may be the workaround for the issue.
Hope to help
Giuseppe
we found out that all ports on this switch are showing no input/output packets;
for example we checked both uplinks are having no input/output packets
we check on the opposite side - we see huge traffic input/output packets flow on the uplink
That's nice, however, we still want to see the output to the following commands:
sh controller ether <PORT>
sh version
thank you for your reply;
here show version
------------------ show version ------------------
Cisco IOS XE Software, Version 16.12.02
Cisco IOS Software [Gibraltar], Catalyst L3 Switch Software (CAT9K_LITE_IOSXE), Version 16.12.02, RELEASE SOFTWARE (fc2)
Compiled Tue 19-Nov-19 07:33
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 16.12.1r [FC4], RELEASE SOFTWARE (P)
and show controller is in attachment
Are these the ports having problems? I mean you're not just having issues with one port?
yes, we have same issue on all ports
