interface delay time, what does it mean !?
mohammed hashim
Level 5
Level 5
when we issue command show int gig 1/0
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec
now gig 1/0 is a 1gig ethernet interface
1gig means it can sends 1 billion bits per second (1,000,000,000 bits\s)
interface delay is 10 microsecond. microsecond means 10-6 second,
10 usec is 10-5 second, if you divide the second over this number
1/10-5 =  100000 bits\s (100 kbit\s)
which does not match the actual interface speed,
so what does the interface delay timer means ?
Julio E. Moisa
Please check this link:
https://supportforums.cisco.com/discussion/10714466/delay-setting-interface-what-does-it-mean
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
