Interface Discard
Rawa Salah
Dears
please could you help me ? in my c3750 i put 3 port to the portchannel  , and the portchannel has traffic of 2 gigbps , and  i see in the Solarwinds that this portchannel has   1000 trasmit  packet discard
i can check what for solving that ?
Leo Laohoo
Post the output to the following commands:
1.  sh interface Gi ;
2.  sh controller e Gi
Do not run the two commands on the port-channel interfaces.  I want to see the outputs of the physical interfaces of the port-channels.  Please do not post screenshots.
Thanks Leo
port 20,21 int one portchannel , port 22,23,24 in another portchannel , both portchannel has discard transmit packet , find the output below :
Border-Switch#sh int gig 1/0/20
GigabitEthernet1/0/20 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0006.f627.b6cc (bia 0006.f627.b6cc)
  Description: " TO - RA "
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 27/255, rxload 7/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:17, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 423575
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 28814000 bits/sec, 19133 packets/sec
  5 minute output rate 108610000 bits/sec, 13189 packets/sec
     44607608984 packets input, 8017295227273 bytes, 0 no buffer
     Received 27171 broadcasts (26623 multicasts)
     0 watchdog, 26623 multicast, 0 pause input
     30241067594 packets output, 29386888037096 bytes, 0 underruns
Border-Switch#sh int gig 1/0/21
GigabitEthernet1/0/21 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0006.f627.b6cd (bia 0006.f627.b6cd)
     reliability 255/255, txload 28/255, rxload 1/255
  Last input 00:00:20, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 417249
  5 minute output rate 112392000 bits/sec, 13534 packets/sec
     7468831 packets input, 1354573868 bytes, 0 no buffer
     Received 26577 broadcasts (26577 multicasts)
     0 watchdog, 26577 multicast, 0 pause input
     30179041791 packets output, 29361879783485 bytes, 0 underruns
Border-Switch#sh int gig 1/0/22
GigabitEthernet1/0/22 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0006.f627.b6ce (bia 0006.f627.b6ce)
  Description: " To - RB "
     reliability 255/255, txload 20/255, rxload 1/255
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 79039
  5 minute input rate 7660000 bits/sec, 5361 packets/sec
  5 minute output rate 78733000 bits/sec, 8652 packets/sec
     13893630184 packets input, 2429526821914 bytes, 0 no buffer
     Received 26586 broadcasts (26586 multicasts)
     0 watchdog, 26586 multicast, 0 pause input
     21087011411 packets output, 21062927276022 bytes, 0 underruns
Border-Switch#sh int gig 1/0/23
GigabitEthernet1/0/23 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0006.f627.b6cf (bia 0006.f627.b6cf)
     reliability 255/255, txload 13/255, rxload 1/255
  Last input 00:00:21, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 15680
  5 minute input rate 6763000 bits/sec, 4887 packets/sec
  5 minute output rate 53628000 bits/sec, 6287 packets/sec
     13257116201 packets input, 2321922995134 bytes, 0 no buffer
     Received 26863 broadcasts (26585 multicasts)
     0 watchdog, 26585 multicast, 0 pause input
     17529945211 packets output, 17523296345260 bytes, 0 underruns
Border-Switch#sh int gig 1/0/24
GigabitEthernet1/0/24 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0006.f627.b6d0 (bia 0006.f627.b6d0)
     reliability 255/255, txload 17/255, rxload 1/255
  Last input 00:00:04, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 13478
  5 minute input rate 6761000 bits/sec, 4932 packets/sec
  5 minute output rate 70306000 bits/sec, 7704 packets/sec
     13250519109 packets input, 2313657706108 bytes, 0 no buffer
     Received 26592 broadcasts (26589 multicasts)
     0 watchdog, 26589 multicast, 0 pause input
     17547294517 packets output, 17521328532373 bytes, 0 underruns
Please no one can help my Case ?
