interface fa1/0/26 connected to a switch, goes in err-disable state even after NO SH.
rehan alam
I am cascading one new switch 3750G (int Gi1/0/1) with an existing 3750G (int fa1/0/26) switch.. But the interface fa1/0/26 goes in err-disable state even after NO SH.. also i have diable Spanning treebpdu guard and disable spanning tree portfast. But still the issue is not resolved.
Please help.
could you please try this please:
New Switch
int GigabitEthernet1/0/1
switchport trunk encap dot1q
switchport mode trunk
speed 100
duplex full
snmp trap link-status
spanning-tree bpduguard disable
end
Existing Switch
int FastEthernet1/0/26
speed 100
duplex full
end
If you want spanning-tree portfast this is an option i think, but i'd rather leave this out for now due to t'shooting this problem:
Switch(config-if)#spanning-tree portfast trunk
%Warning: portfast should only be enabled on ports connected to a single
host. Connecting hubs, concentrators, switches, bridges, etc... to this
interface  when portfast is enabled, can cause temporary bridging loops.
Use with CAUTION
Switch(config-if)#
But as the message says, please use this with caution. Show interface would be useful... and show interface status err
There are various reasons for the interface to go into errdisable. The reason can be:
  • Duplex mismatch
  • Port channel misconfiguration
  • BPDU guard violation
  • UniDirectional Link Detection (UDLD) condition
  • Late-collision detection
  • Link-flap detection
  • Security violation
  • Port Aggregation Protocol (PAgP) flap
  • Layer 2 Tunneling Protocol (L2TP) guard
  • DHCP snooping rate-limit
  • Incorrect GBIC / Small Form-Factor Pluggable (SFP) module or cable
  • Address Resolution Protocol (ARP) inspection
  • Inline power
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a00806cd87b.shtml
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
6 Replies 6
Bilal Nawaz
Could you kindly post the configs of both ports please.
Do a 'show int sta err-dis' once the port is disabled.
Please find the configuration
New Switch
duplex auto
speed auto
  spanning-tree portfast default
end
Existing Switch
duplex auto
speed auto
end
New Switch
speed 100
duplex full
end
Existing Switch
speed 100
duplex full
end
Use with CAUTION
Switch(config-if)#
  • Duplex mismatch
  • Inline power
Its done now.. thanks for the help Bilal.
its showing connected now..can ping the new switch IP. But new switch is not authenticating with Tacacs .. working to resolve the same.
Make sure your new switch management IP is in ACS as an AAA device?
and that all config is in place to cater for tacacs+
You're welcome!
