Interface flapping after bandwidth upgrade
deepak george
Level 3
Level 3
Dear All,
After a bandwidth upgrade from 10 mpbs to 20 mbps, the interface keeps flapping intermittently on a nexus 5k switch. The switch is connected to 3750 located at another location. We could observe that cdp neighborship flap occurs only on the Nexus 5k switch and there are no logs observed on 3750 switch. Please hep as to what could cause the issue
Leo Laohoo
Post the output to the command "sh interface <BLAH>" on both ends.
The link between Nexus and 3750, is it copper or fibre optic?
What is the exact model of the 3750?  Is it a plain FE, G, E or X?
Hi Leo,
Thank you for getting back with your questions.We are only observing  that the cdp neighborship flaps and comes up within 121 sec on Nexus 7k switches,without any link down alarms. However the customer faces a downtime during this period.No logs are observed on the 3750 switch
Is this possible, if only CDP flaps why should there be an outage during that period. The speed and duplex settings have been hardcoded to full and 100 mpbs
Fibre optic
The exact model is 3750e.
Show interface Ethernet2//2
R1##  sh int eth2/2
Ethernet2/2 is up
admin state is up, Dedicated Interface
  Hardware: 10/100/1000 Ethernet, address: 4055.4015.b674(bia 30e4.dbc1.05b0)
  Description: ***Connected to 3750  Internet Address is 10.1.1.1/30
  MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec
  reliability 255/255, txload 11/255, rxload 28/255
  Encapsulation ARPA, medium is broadcast
  Port mode is routed
100 Mb/s  full-duplex,
  Beacon is turned off
  Auto-Negotiation is turned on
  Input flow-control is off, output flow-control is off
  Auto-mdix is turned on
  Switchport monitor is off
  EtherType is 0x8100
  EEE (efficient-ethernet) : n/a
  Last link flapped 2d17h
  4 interface resets
  Load-Interval #1: 30 seconds
    30 seconds input rate 11224580 bits/sec, 1112 packets/sec
    30 seconds output rate 4332124 bits/sec, 1140 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    300 seconds input rate 11433944 bits/sec, 1317 packets/sec
    300 seconds output rate 4060360 bits/sec, 1014 packets/sec
  L3 in Switched:
    ucast: 4673149810 pkts, 594555598148 bytes - mcast: 108 pkts, 7488 bytes
  L3 out Switched:
    ucast: 3000051974 pkts, 913035545316 bytes - mcast: 0 pkts, 0 bytes
  RX
    4674311181 unicast packets  71666 multicast packets  276 broadcast packets
    4674394567 input packets  5945608808888 bytes
    0 jumbo packets  0 storm suppression packets
    0 runts  0 giants  0 CRC/FCS  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    204 Rx pause
  TX
    3000206964 unicast packets  71523 multicast packets  23 broadcast packets
    3000278687 output packets  913067890991 bytes
    0 jumbo packets
    0 output error  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble  0 output discard
    0 Tx pause
No line errors received from the 3750E.  So can you post the output to the command "sh interface <BLAH>" from the 3750E side?
