Interface Flapping
Hello all,
since few months ago we are having problems with some network interfaces where we have Solaris servers connected on our Catalyst 6500 with the following configuration:
interface GigabitEthernet1/4/36
description 1/17/11_PALMERA1-ACCESOUNIX
switchport
switchport access vlan 101
switchport mode access
spanning-tree portfast edge
spanning-tree bpdufilter enable
spanning-tree bpduguard enable
The interfaces of the Solaris servers are part of a cluster using Veritas software and the traffic on the switch interfaces are outbound how int can see on the beginning output:
GigabitEthernet1/4/36 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is e05f.b97a.ebbb (bia e05f.b97a.ebbb)
  Description: 1/17/11_PALMERA1-ACCESOUNIX
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseT
  input flow-control is off, output flow-control is off
  Clock mode is auto
  Last input never, output 00:00:16, output hang never
  Last clearing of "show interface" counters 12w0d
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 1000 bits/sec, 1 packets/sec
    0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     17385683 packets output, 1417944779 bytes, 0 underruns
We have opened a query to Oracle support and they have said that this is the normal operation but on the switches, the interfaces are flapping
continuously:
1367804: Sep 11 2012 17:32:52: %PARSER-5-CFGLOG_LOGGEDCMD: User:ism  logged command:interface GigabitEthernet1/4/36
1367839: Sep 11 2012 17:33:07: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/36, changed state to down
1367840: Sep 11 2012 17:33:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/36, changed state to down
1367841: Sep 11 2012 17:33:07: %LINK-SW1_SP-3-UPDOWN: Interface GigabitEthernet1/4/36, changed state to down
1367842: Sep 11 2012 17:33:08: %LINEPROTO-SW1_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/36, changed state to down
1367858: Sep 11 2012 17:33:14: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/36, changed state to up
1367859: Sep 11 2012 17:33:14: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/36, changed state to up
1367861: Sep 11 2012 17:33:14: %LINK-SW1_SP-3-UPDOWN: Interface GigabitEthernet1/4/36, changed state to up
1367862: Sep 11 2012 17:33:14: %LINEPROTO-SW1_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/36, changed state to up
1367919: Sep 11 2012 17:34:43: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/36, changed state to down
1367921: Sep 11 2012 17:34:43: %LINK-SW1_SP-3-UPDOWN: Interface GigabitEthernet1/4/36, changed state to down
1367923: Sep 11 2012 17:34:44: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/36, changed state to down
1367926: Sep 11 2012 17:34:44: %LINEPROTO-SW1_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/36, changed state to down
1367934: Sep 11 2012 17:34:46: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/36, changed state to up
1367935: Sep 11 2012 17:34:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/36, changed state to up
1367936: Sep 11 2012 17:34:46: %LINK-SW1_SP-3-UPDOWN: Interface GigabitEthernet1/4/36, changed state to up
1367937: Sep 11 2012 17:34:46: %LINEPROTO-SW1_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/36, changed state to up
1367938: Sep 11 2012 17:34:49: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/36, changed state to down
1367939: Sep 11 2012 17:34:50: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/36, changed state to down
1367940: Sep 11 2012 17:34:49: %LINK-SW1_SP-3-UPDOWN: Interface GigabitEthernet1/4/36, changed state to down
1367941: Sep 11 2012 17:34:50: %LINEPROTO-SW1_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/36, changed state to down
1367942: Sep 11 2012 17:34:53: %LINK-3-UPDOWN: Interface GigabitEthernet1/4/36, changed state to up
1367943: Sep 11 2012 17:34:53: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/36, changed state to up
1367944: Sep 11 2012 17:34:53: %LINK-SW1_SP-3-UPDOWN: Interface GigabitEthernet1/4/36, changed state to up
1367946: Sep 11 2012 17:34:53: %LINEPROTO-SW1_SP-5-UPDOWN: Line protocol on Interface GigabitEthernet1/4/36, changed state to up
Has anyone the same problem or that knows what is it happening?
Although this behavior does not impact on the production services, fills the local log of the switch; and if we need to find some event, it is imposible mission!
Regards and thanks a lot.
Julio Carvajal
Hello Iker,
The interface is running  Full-duplex, 1000Mb/s.. Can you check if the Solaris server nic card  is also running that.
Have you change the cable between each other?
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Yes,
the interface NIC is Full-Duplex/1000Mb/s and the first change that we made was the cable and nothing.
When the flaps occur, in the server side, the interface is in "unknonw" state and not leave any log on the server.
The state "unknonw" of interface on the server is reached at the following times:
  • When the interface is not configured on the server and it is connected to the switch (the switch detects the link)
  • When the interface is part of a Veritas Cluster on "active-passive" mode.The interface configured like "passive" inside the cluster, appears in "unknown" state becuase the script misconfigured the interface and only configured it when the interface becomes the "active"
For these reasons we asked to Oracle Technical Support but they say that is normal and all is ok...
We are thinking in disable link status logging on the switch for those interfaces but, in my opinion, it is not the solution.
The model of server card is Broadcom Gigabit Ethernet.
Thank you.
