interface getting down N9300-4503 vPC
jen2181918
Frequent Visitor
Frequent Visitor
I have two cisco Nexus 93108TC Chassis Im having problem with the traffic going in and out the interface, please let me know what I missed.
Thank you in advance.
From the logging:
zhongxinjifang9300-1 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-
channel2: first operational port changed from Ethernet1/49 to none
2020 Jun 21 07:03:11 zhongxinjifang9300-1 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel2: Ethernet1/49 is down
2020 Jun 21 07:03:11 zhongxinjifang9300-1 %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBER
S_DOWN: Interface port-channel2 is down (No operational members)
2020 Jun 21 07:03:11 zhongxinjifang9300-1 %ETHPORT-5-IF_BANDWIDTH_CHANGE: Interface port-channel2,bandwidth changed to 100000 Kbit
2020 Jun 21 07:03:11 zhongxinjifang9300-1 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/49 is down (Link failure)
2020 Jun 21 07:03:12 zhongxinjifang9300-1 %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBER
2020 Jun 21 07:03:12 zhongxinjifang9300-1 last message repeated 1 time
2020 Jun 21 07:03:12 zhongxinjifang9300-1 %ETHPORT-5-SPEED: Interface Ethernet1/
49, operational speed changed to 1 Gbps
2020 Jun 21 07:03:12 zhongxinjifang9300-1 %ETHPORT-5-IF_DUPLEX: Interface Ethern
et1/49, operational duplex mode changed to Full
2020 Jun 21 07:03:12 zhongxinjifang9300-1 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interfa
ce Ethernet1/49, operational Receive Flow Control state changed to off
2020 Jun 21 07:03:12 zhongxinjifang9300-1 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interfa
ce Ethernet1/49, operational Transmit Flow Control state changed to off
2020 Jun 21 07:03:12 zhongxinjifang9300-1 %ETHPORT-5-SPEED: Interface port-chann
el2, operational speed changed to 1 Gbps
2020 Jun 21 07:03:12 zhongxinjifang9300-1 %ETHPORT-5-IF_DUPLEX: Interface port-c
hannel2, operational duplex mode changed to Full
ce port-channel2, operational Receive Flow Control state changed to off
ce port-channel2, operational Transmit Flow Control state changed to off
2020 Jun 21 07:03:13 zhongxinjifang9300-1 %ETH_PORT_CHANNEL-5-PORT_UP: port-chan
nel2: Ethernet1/49 is up
2020 Jun 21 07:03:13 zhongxinjifang9300-1 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-
channel2: first operational port changed from none to Ethernet1/49
2020 Jun 21 07:03:13 zhongxinjifang9300-1 %ETHPORT-5-IF_BANDWIDTH_CHANGE: Interf
ace port-channel2,bandwidth changed to 1000000 Kbit
2020 Jun 21 07:03:13 zhongxinjifang9300-1 %ETHPORT-5-IF_UP: Interface Ethernet1/
49 is up in mode trunk
2020 Jun 21 07:03:13 zhongxinjifang9300-1 %ETHPORT-5-IF_UP: Interface port-chann
el2 is up in mode trunk
2020 Jun 21 07:03:13 zhongxinjifang9300-1 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-ch
2020 Jun 21 07:03:13 zhongxinjifang9300-1 %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBER
2020 Jun 21 07:03:13 zhongxinjifang9300-1 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Inter
2020 Jun 21 07:03:14 zhongxinjifang9300-1 last message repeated 1 time
2020 Jun 21 07:03:14 zhongxinjifang9300-1 %ETHPORT-5-SPEED: Interface Ethernet1/
2020 Jun 21 07:03:14 zhongxinjifang9300-1 %ETHPORT-5-IF_DUPLEX: Interface Ethern
2020 Jun 21 07:03:14 zhongxinjifang9300-1 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interfa
zhongxinjifang9300-1 %TAHUSD-SLOT1-4-BUFFER_THRESHOLD_EXCEE
DED: Module 1 Instance 0 Pool-group buffer 90 percent threshold is exceeded!
Mark Elsen
 - Check the physical-health of the particular connection.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thank you for your reply。
I want to ask the meaning of this log:
2020 Jun 21 07:03:50zhongxinjifang9300-1 %TAHUSD-SLOT1-4-BUFFER_THRESHOLD_EXCEE
The down message that appears  sometimes few minutes, few hours,or half a day, or one day.
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Inter
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBER
2020 Jun 18 17:34:19 zhongxinjifang9300-1 last message repeated 1 time
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETHPORT-5-SPEED: Interface Ethernet1/
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETHPORT-5-IF_DUPLEX: Interface Ethern
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interfa
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interfa
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETHPORT-5-SPEED: Interface port-chann
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETHPORT-5-IF_DUPLEX: Interface port-c
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETH_PORT_CHANNEL-5-PORT_UP: port-chan
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETHPORT-5-IF_BANDWIDTH_CHANGE: Interf
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETHPORT-5-IF_UP: Interface Ethernet1/
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETHPORT-5-IF_UP: Interface port-chann
2020 Jun 19 06:08:38 zhongxinjifang9300-1 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-
2020 Jun 19 06:08:38 zhongxinjifang9300-1 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-ch
2020 Jun 19 06:08:39 zhongxinjifang9300-1 %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBER
2020 Jun 19 06:08:39 zhongxinjifang9300-1 %ETHPORT-5-IF_BANDWIDTH_CHANGE: Interf
2020 Jun 19 06:08:39 zhongxinjifang9300-1 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Inter
2020 Jun 19 06:08:39 zhongxinjifang9300-1 last message repeated 1 time
2020 Jun 19 06:08:39 zhongxinjifang9300-1 %ETHPORT-5-SPEED: Interface Ethernet1/
2020 Jun 19 06:08:39 zhongxinjifang9300-1 %ETHPORT-5-IF_DUPLEX: Interface Ethern
2020 Jun 19 06:08:39 zhongxinjifang9300-1 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interfa
2020 Jun 19 06:08:39 zhongxinjifang9300-1 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interfa
2020 Jun 19 06:08:40 zhongxinjifang9300-1 %ETHPORT-5-SPEED: Interface port-chann
2020 Jun 19 06:08:40 zhongxinjifang9300-1 %ETHPORT-5-IF_DUPLEX: Interface port-c
2020 Jun 19 06:08:40 zhongxinjifang9300-1 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interfa
2020 Jun 19 06:08:40 zhongxinjifang9300-1 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interfa
2020 Jun 19 06:08:40 zhongxinjifang9300-1 %ETH_PORT_CHANNEL-5-PORT_UP: port-chan
2020 Jun 19 06:08:40 zhongxinjifang9300-1 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-
2020 Jun 19 06:08:40 zhongxinjifang9300-1 %ETHPORT-5-IF_BANDWIDTH_CHANGE: Interf
2020 Jun 19 06:08:40 zhongxinjifang9300-1 %ETHPORT-5-IF_UP: Interface Ethernet1/
2020 Jun 19 06:08:40 zhongxinjifang9300-1 %ETHPORT-5-IF_UP: Interface port-chann
2020 Jun 19 06:08:40 zhongxinjifang9300-1 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-ch
2020 Jun 19 06:08:40 zhongxinjifang9300-1 %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBER
2020 Jun 19 06:08:40 zhongxinjifang9300-1 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Inter
2020 Jun 19 06:08:41 zhongxinjifang9300-1 last message repeated 1 time
2020 Jun 19 06:08:41 zhongxinjifang9300-1 %ETHPORT-5-SPEED: Interface Ethernet1/
2020 Jun 19 06:08:41 zhongxinjifang9300-1 %ETHPORT-5-IF_DUPLEX: Interface Ethern
2020 Jun 19 06:08:41 zhongxinjifang9300-1 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interfa
2020 Jun 19 06:08:41 zhongxinjifang9300-1 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interfa
2020 Jun 19 06:08:41 zhongxinjifang9300-1 %ETHPORT-5-SPEED: Interface port-chann
2020 Jun 19 06:08:41 zhongxinjifang9300-1 %ETHPORT-5-IF_DUPLEX: Interface port-c
2020 Jun 19 06:08:41 zhongxinjifang9300-1 %ETH_PORT_CHANNEL-5-PORT_UP: port-chan
2020 Jun 19 06:08:41 zhongxinjifang9300-1 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-
2020 Jun 19 06:08:41 zhongxinjifang9300-1 %ETHPORT-5-IF_BANDWIDTH_CHANGE: Interf
2020 Jun 19 06:08:41 zhongxinjifang9300-1 %ETHPORT-5-IF_UP: Interface Ethernet1/
2020 Jun 19 06:08:42 zhongxinjifang9300-1 %ETHPORT-5-IF_UP: Interface port-chann
 - It could mean , that you 'only' have a physical connection problem on the link. Disconnect and re-connect at both sides (for instance).
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Hi @jen2181918
The message: "Module 1 Instance 0 Pool-group buffer 90 percent threshold is exceeded" means that the buffer is reaching the limit of 100% utilization. This happens basically due to a congestion on the interface which is either caused by over utilization of the egress port (1x 10G ingress, 1x 1G egress OR 2x 1G ingress, 1x 1G egress), either by micro bursts of traffic which is eating up the buffers.
I would recommend you monitor the interface utilization and see if it reaches the limits. if yes, then you will need more bandwidth for the egress (port-channeling) or you can apply QoS and prioritize the important traffic. Note, the last option will only avoid traffic drops for higher priority classes.
The link flaps, looks like a separate issue - you will have to perform a L1 check:
+ verify/replace  the SFPs
+ verify/replace the cable/fiber
+ verify that the cable/connectors/SFP are properly inserted
+ if you changed all of the above, start moving the SFPs/cables to another switch port OR another NIC.
Stay safe,
Sergiu
