Interface is blocking by stp
Muthukumar P
Level 4
Level 4
Hi team,
             We are having one Cisco 2960 switch one HPE 5900 switch and need to connect the uplink between. When ever connect the link between switches getting error message and it seems cisco switch port blocking stage but HPE switch interface is showing forward mode. the following error are getting. Kindly suggest on this..
Note: In cisco switch default vlan only configured and HPE switch side number of vlans are configured. We have tried
both switch uplink port trunk as well as access port but same problem persisting
​​​​*Nov 14 00:10:45.706: %SPANTREE-7-BLOCK_PORT_TYPE: Blocking GigabitEthernet1/0/47 on VLAN0001. Inconsistent port type.
HI team,
         The following configuration is ok for enable MST
instance 1 vlan 10-20
name region1
revision 1
show pending
7 Replies 7
Mark Elsen
 - Check this article :
         https://community.cisco.com/t5/networking-documents/the-quot-spantree-7-block-port-type-blocking-chars-on-chars/ta-p/3132678
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
OK I will try and confirm by tomorrow
FYI..
Cisco switch side PVST is enabled
HPE switch side MSTP is running
PVST is Cisco proprietary. Try and run MSTP on both the Cisco and the HPE.
Muthukumar P
Level 4
Level 4
Today only we are going to check and will confirm the status by soon
Hi Team,
HI team,
name region1
revision 1
show pending
Hello
Make sure they are both running the same port mode,(trunk or access) and if a trunk native vlan is the same, we have cisco and HP running fine in our environments but you DO need to check the stp modes incase when pvst and mst domains connect.
Can you confirm what switch is the stp root, I assume its the HP as that's running multiple vlans- if so change the stp bridge id of the cisco switch to a  higher / stp lesser value than the HP switch ( no need to change stp mode on the cisco either)
cisco switch
spanning-tree vlan 1-4094 priority 61440
Kind Regards
Paul
