Interface Output Errors
abhayjoshi07
Visitor
Hi All,
I have wierd issue going on within network. There is a file server which is behind firewall connected to gig4/0/19 (output shown below). If the users in production network try to access this file server the speed is very slow (approx 50kbps) whereas the speed of this link is 1gig. I am not sure why the speed is so slow. Can anyone please provide inputs on this issue.
GigabitEthernet4/0/19 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 5835.d9ec.f293 (bia 5835.d9ec.f293)
  Description: **Print-Prod Switchports**
  MTU 9000 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:27, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1885
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 767000 bits/sec, 52 packets/sec
  5 minute output rate 18000 bits/sec, 26 packets/sec
     46409954 packets input, 34977983377 bytes, 0 no buffer
     Received 59758 broadcasts (1103 multicasts)
     0 watchdog, 1103 multicast, 0 pause input
     68069335 packets output, 59947447282 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
Whats the interface settings on the fileserver?
Is the file server interface showing any errors
res
Paul
Please don't forget to rate this post if it has been helpful.
Kind Regards
Paul
Do this
Change Duplex and Speed Setting to auto on both Server and Switchport
or
changle Duplex and speed Setting to Manula on boht Server and Switchport
Also
Check if there any firewalll enabled in File Server.
Please Rate if find Helpful
Jawad
Below is the file server interface settings:
interface GigabitEthernet4/0/19
description **Print-Prod Switchports**
switchport access vlan 105
switchport mode access
switchport port-security maximum 2
switchport port-security aging time 2
switchport port-security violation restrict
switchport port-security aging type inactivity
spanning-tree portfast
spanning-tree bpduguard enable
end
QoS is also enabled for end user ports. Below is the sample config for one of the end user port. Does this affect how the traffic is processed by the file server port:
interface GigabitEthernet1/0/10
description Enduser-IP-Phones
switchport voice vlan 172
srr-queue bandwidth share 1 30 35 5
queue-set 2
priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
service-policy input AUTOQOS-SRND4-CISCOPHONE-POLICY
end
