interface range vs comma
alexmarin28
Community Member
Is it possible to do an interface range with more than 5 comma on a catalyst 2960x?
Thanks in advance
Peter Paluch
Hi Alex,
I am afraid it won't be possible. I have tested a Catalyst 3560G and in the interface range command, I was able to use only 4 commas to separate 5 distinct subranges. As these Catalysts mostly run very similar IOSes, I am forced to believe that the behavior would be the same.
Best regards,
Peter
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
My experience, across different Cisco routers and switches, also has been interface range is limited to 4 commas (some devices requiring spaces around them, some not [usually older vs. newer IOS versions]).  I may have seen some difference on a Nexus, but don't quote me on that.
