Interface reset
Pavan Parvathaneni
Frequent Visitor
Frequent Visitor
We are having Cisco 2960X switches for access-layer. From past one week we are noticing sudden drop on voip & meeting sessions with Skype, Webex, Teams. After doing troubleshooting we noticed that there is increase in interface reset on switchport connecting to end-user. We would like to know if Interface reset can cause Network connection issues like drop in connections.
sh int Gi1/0/24 | i reset
0 output errors, 0 collisions, 3 interface resets
Please reply for solutions.
6 Replies 6
Reza Sharifi
3 resets is not a whole a lot. Can you post the output of "sh int g1/0/24 and also "sh run int g1/0/24"?
Pavan Parvathaneni
Frequent Visitor
Frequent Visitor
SW000CISE#sh int Gi1/0/24
GigabitEthernet1/0/24 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is f8b7.e260.5698 (bia f8b7.e260.5698)
Description: To Ames07-IT Access Point
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 00:00:01, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 692134
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 61000 bits/sec, 48 packets/sec
5 minute output rate 4169000 bits/sec, 392 packets/sec
547876748 packets input, 191421821324 bytes, 0 no buffer
Received 16140099 broadcasts (13553928 multicasts)
0 watchdog, 13553928 multicast, 0 pause input
1545509532 packets output, 1668545577719 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
SW000CISE#sh run int Gi1/0/24
Building configuration...
Current configuration : 131 bytes
interface GigabitEthernet1/0/24
description To Ames07-IT Access Point
switchport access vlan 1010
switchport mode access
end
I cleared counters on the interface. when a meeting is going user connections are getting disconnected. I have noticed an increment interface reset of 18 counters. Then again I have noticed 3 recent errors.
So, this port is connecting to an access point? I also see this
For testing, can you hard set the interface to whatever speed the access point support and monitor again?
I hard reset the interface speed to 1000.
I agree with @Reza Sharifi that the total output drops may be significant. An interface reset reflects a situation where the interface has attempted to send data but has not been successful. After a number of attempts to retransmit have not been successful the interface will reset in an attempt to clear the issue. The number of total output drops might suggest a capacity mismatch between the switch and the access point.
Rick
Rick
