interface resets
carl_townshend
Hi all
Can anyone tell me what interface resets are? why they happen and what causes them ?
Justin Brenton
Level 4
Level 4
Hi Carl,
interface resets
Number of times an interface has been completely reset. This can happen if packets queued for transmission were not sent within several seconds. On a serial line, this can be caused by a malfunctioning modem that is not supplying the transmit clock signal, or by a cable problem. If the system notices that the carrier detect line of a serial interface is up, but the line protocol is down, it periodically resets the interface in an effort to restart it. Interface resets can also occur when an interface is looped back or shut down.
Justin
