interface restrictions
suthomas1
Level 6
Level 6
Good day all,
In a layer 3 switch with multiple svi, how can we disable ssh access for all the svi interfaces.
If a switch has 3 vlans - vlan 10, vlan 11, vlan 12 ; these svi should not permit any ssh or telnet service to it.
These vlan interface do not have any acl on them.
those services should be only through management designated interfaces.
Hello @suthomas1 ,
I am afraid the source-interface command is effective only for outbound SSH sessions when the device is used to connect in SSH to another device.
To force incoming SSH sessions to be accepted only on one specific interface I think you should use an IP extended ACL applied to the line vty
something like
access-list 111 permit tcp any host 192.168.1.1 eq 22
line vty 0 4
access-class 111 in
But I advise you that using extended ACLs on line vty it is tricky and can lead to undesired results.
Hope to help
Giuseppe
balaji.bandi
how about configuring source interface.
ip ssh source-interface interface
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/security/d1/sec-d1-cr-book/sec-cr-i3.html#wp5893687220
You can also have simple ACL to coming in to VTY Lines - example
ip access-list standard ALLOW-SSH
permit 192.168.100.0 0.0.0.255
line vty 0 15
transport ssh
access-class ALLOW-SSH in
BB
we want to avoid using access list. if all vlans can be permitted not be used for ssh access with the use of that source-interface command, then that is the preferred choice.
appreciate the help.
Hello @suthomas1 ,
something like
line vty 0 4
access-class 111 in
Hope to help
Giuseppe
