Interfaces identified as GigbitEhternet2/0/x when not in a stack
kevin.patsie
I have a 2960x that used to be in a member in a stack. This switch has been factory reset. After reset all the interfaces are being identified as GigabitEthernet2/0/1 to GigabitEhternet2/0/48. How can I clear this and get it back to GigabitEthernet1/0/1 to GigabitEhternet1/0/48?
Kevin
%switch can not be un-provisioned when it is physically present
Ahhhhhh ... Now I get it.
Ok, here's the low-down to this.  The switch is coming up as a stack switch member 2 (and not member 1).  So this means that switch will need to be "renumbered", however, this means that when the switch gets renumbered the switch will need to get a reboot and the ports will loose all the configuration.
The command to renumber the switch is "switch 2 renumber 1".  Save the config and reload.
7 Replies 7
Leo Laohoo
This is normal behaviour if there was a previous stack member or if someone has pre-provisioned an additional stack member.  To remove the 2nd stack member from the list, just look at the config and there should be a line like "provision 2 <model number>" and issue a "no".
It does have a line in the config saying
switch 2 provision ws-2960-48fpd-l
however if I try to run
no switch 2 provision ws-2960-48fpd-l
it says
Hi Kevin -
You can change the switch number with the following config command:
switch 2 renumber 1
You will need to reboot the switch (and likely reconfigure all the interfaces) after the change.
Good Luck,
PSC
Ok it was indeed switch 2. I ran the command to renumber
switch 2 renumber 1
then had to run the following to get it out of the configuration
Now the switch running configuration looks correct.
thank you both. not sure who to mark as correct since it took both commands to straighten out.
Hi -
Leo gave first and correct answers.  He gets credit. :)
*cough*, bullsh!t,*cough*
We collaborated.  We both can get the "Answered" score.   It won't "cost" the OP anything.  :)
