Interfaces, Schedule Uptime
adhonysdiaz
Community Member
Hi, I have a problem.
Is there any command to make an schedule to up each interface of a switch in a specific time?
Georg Pauwen
in addition to Joseph's remarks, here is an example of two EEM scripts. The first script would unshut the interfaces at 9AM Monday thru Friday, the second one would shut the interfaces at 5PM Monday thru Friday.
event manager applet INTERFACES_UP
event timer cron cron-entry "0 9 * * 1-5"
action 1.0 cli command "enable"
action 2.0 cli command "conf t"
action 3.0 cli command "interface range GigabitEthernet 0/0 - 10"
action 4.0 cli command "no shut"
action 5.0 cli command "end"
event manager applet INTERFACES_DOWN
event timer cron cron-entry "0 17 * * 1-5"
action 4.0 cli command "shut"
Joseph W. Doherty
If the switch supports EEM, I believe you can write a script and schedule it so that it will enable/disable an interface when desired.
Georg Pauwen
