interfaces
phaniraj01
Community Member
what is meant by ethernet1/0/12
mohammedmahmoud
Level 11
Level 11
What is the platform that you are connecting this ethernet interface to?
BR,
Mohammed Mahmoud.
smothuku
Level 11
Level 11
Hi ,
ethernet 1/0/12 means 1 refers to slot and 0/12 refers to port.
incase if you insert any ethernet module in second slot of a router then interface notation would be ethernet 2/0/12. 2 means second slot , 0/12 means port in which you are going to connect devices.
Satish
thanks
what about it is in case of switch ethernet 1/0/12
