12-31-2010 07:45 AM - edited 03-06-2019 02:46 PM
I have been having a problem and have opened up a ticket via TAC but still nothing fixed. I can't call internal extensions to any of my other device pools but they can all call each other. When I call they pick up and I hear them but they can't hear me. I have replaced the router(thinking maybe the router was going out) but with no fix. I need help please. Thanks!!!!
12-31-2010 08:41 AM
Shane,
Please provide your entire configuration and an exact description which call works as expected and which call does not work.
Best regards,
Peter
12-31-2010 08:54 AM
External calls work and all internal calls to/from Main Location do not. Every other branch works to each other is okay. This problem started with one branch and now can't call anyone. We had this happen about 6 months ago to one branch and I reloaded the switches and router at that branch and it has never happen again.
Here is my router Config:
C
end
12-31-2010 09:00 AM
Shane,
This is not specific enough. Can I ask you to answer the following questions?
Best regards,
Peter
12-31-2010 09:05 AM
I called from 6316 10.0.10.78 to 642710.0.13.31
Works fine
I call from 6316 10.0.10.78 to 6450 10.0.11.66
No Audio
12-31-2010 09:30 AM
Shane,
Thank you for your responses. The router configuration does not seem to imply it is running a Call Manager Express - I assume that you are using an external call manager or an equivalent service to perform call routing.
What I would try to do is to perform packet capture to see
The fact that the called endpoint actually can be called proves that the basic signalling is working. However, as the parties can not hear each other, it has to be determined if the media stream is properly generated and addressed, and whether it is being delivered. An inappropriately configured firewall can be blocking the media stream, rendering the call "silent".
Best regards,
Peter
