internal power supply cisco 2960
Good day to all.
I have 3 switches that are not working anymore (2960) after checking i found out that the internal power supply is broken.
this power supply is a lose unit you can easly take it out.
Does someone knows where i can buy new ones ? or is it just bad luck and you can't buy these powersuplies.
The part number is 341-0097-03
Thanks for your time!
5 Replies 5
Leo Laohoo
Can you supply the part number of the power supply?
I think the partnumber should be:
Power supply part number 341-0097-03
Silly me.  I meant SERIAL number.
No problem
Serialnumber is DCA154584NF
Thanks for your assistance!
DCA ... I've never heard of this manufacturing company.
If the serial number starts with LIT then the manufacturer of the power supply would be LITEON.
