Internal router and static routing issue
sfanayei
Hi!
I have a Cisco 6006 router that is configured with som subnets as vlan interfaces. And i have connected a Cisco 1812 to the router 6006. I can ping both F0 and F1 interface ip address on Cisco 1812 from 6006 but nor from other vlan interfaces. All vlans are directly connected to Cisco 6006. What it is possible problem? Many tanks in advance for any help. Please see attached network diagram dokument.
Regards sfanayei
Nagaraja Thanthry
Does the 1800 router have a route to those VLANs? Please make sure that
there is route entry for all the VLANs on the 1800 router.
Hope this helps.
NT
Nagaraja Thanthry
Hope this helps.
NT
Hi NT
Tanks for your reply, Those two interface F0 and F1 are member of vlans who are connected dirctely to my core router. And I have implemnted your slution, but still not working. I can ping both interface ip from other vlans and from indside router 1800 to the ip indside, but still not connection to thr outside world. Here is part of my configuration:
interface FastEthernet0
ip address 10.96.2.10 255.255.255.0
no ip route-cache
speed 100
full-duplex
interface FastEthernet1
ip address 192.xx.yy.242 255.255.255.0
no ip route-cache
speed 100
full-duplex
ip route 0.0.0.0 0.0.0.0 192.xx.yy.1
ip route 192.xx.yy.0 255.255.255.0 192.xx.yy.1
Reza Sharifi
Hi  sfanayei,
In addition to what NT said, can you make sure that the SVIs for vlan 100, 200, 300 are in up and up position?
"sh ip int bri" will show you that.
Reza
