Internal switch modules creating two interfaces
jeff robins
I have a 2911 with an internal switch module(ES3G-16-P). When I install the switch module, the router is creating two seperate interfaces. I have worked with the these switch modules before on the 3845, but I've seen where two interfaces are created. Why are there two? Am I suppose to set up a port channel or can I use just one interface?
Dublin-Border-R1#sh ip int b
Interface                  IP-Address      OK? Method Status                Protocol
Embedded-Service-Engine0/0 unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0         unassigned      YES NVRAM  administratively down down
GigabitEthernet0/1         unassigned      YES NVRAM  administratively down down
GigabitEthernet0/2         unassigned      YES NVRAM  administratively down down
GigabitEthernet1/0         10.1.1.1        YES manual up                    up
GigabitEthernet1/1         unassigned      YES unset  up                    up
Vlan1                      unassigned      YES unset  up                    up
Dublin-Border-R1# sh cdp n
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
                  D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
Dublin-Border-Sw1
                 Gig 1/0            171             S I   SM-ES3G-1 Gig 0/18
Dublin-Border-Sw1
                 Gig 1/1            171             S I   SM-ES3G-1 Gig 0/17
Dublin-Border-R1#
Reza Sharifi
These are 2 redundant ports that connect the router to the switch internally.  You can use separately, but I have never seen them in portchannel. You may want to try it and see if it works.
