Internet connection with Router 877
Mohamed Lotfy
Dear all ,
We have a new internet connection from DSL cisco router 800 Series (877).
You has been delivered it to us with Cisco Router 800 series (Ver 877), when we connect it to the PC directly it’ll work fine with the static IP.
We configured the OSPF between the Switch and the Router. and we can reach to the DSL router IP from our LAN any where.
but we can't exit from the router to the internet.
Please i need your advice
DSL router 877 ---------------> Core Switch 6509 ----> PC
Router 877 (DSL):
version 12.4
no service pad
service password-encryption
hostname Lotfy
boot-start-marker
boot-end-marker
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/35
  pppoe-client dial-pool-number 1
dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description $Internet$
ip address 96.25.31.81 255.255.255.248
ip nat inside!23
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap chap callin
ppp chap hostname xxxxxxxxxxxxx
ppp chap password 7 xxxxxxxxxxxxxxxxxxx
ppp pap sent-username xxxxxxxxxxxxxxxxx password 7 xxxxxxxxxxxx
router ospf 1
log-adjacency-changes
network 96.25.31.80 0.0.0.7 area 0
default-information originate
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 23 permit 10.10.10.0 0.0.0.7
no cdp run
line con 0
no modem enable
line aux 0
line vty 0 4
privilege level 15
password 7 130C04
login local
scheduler max-task-time 5000
end
Core Switch 6509:
interface GigabitEthernet8/25
switchport
switchport access vlan 777
switchport mode access
interface Vlan777
ip address 96.25.31.82 255.255.255.248
end
interface Vlan510
description SW_to_internet
ip address 10.170.10.250 255.255.255.0
end
interface GigabitEthernet8/26
switchport
switchport access vlan 510
router ospf 1
network 10.170.10.0 0.0.0.255 area 0
ip classless
ip route 0.0.0.0 0.0.0.0 96.25.31.81
Verify:
Lotfy#ping 10.170.10.250
Sending 5, 100-byte ICMP Echos to 10.170.10.250, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
DC-BB16509#ping 96.25.31.81
Sending 5, 100-byte ICMP Echos to 96.25.31.81, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
DC-BB1#traceroute 4.2.2.2
Tracing the route to 4.2.2.2
  1 96.25.31.81 4 msec 0 msec 0 msec
  2  *  *  *
  3  *  *  *
  4  *  *  *
  5  *  *  *
5 Replies 5
viswamin
I see some problem wiht the NAT configuration. You have defined the inside interface and the outside interface but haven;t actually performing the NAT translations.
Also can you pls let me know the following details...
1. Which port on the switch is connected to the DSL Router?
2. Does all your PC's on the switch in the same Vlan? if not, the link connecting the switch and the rotuer should be a trunk link.
-Vijay
Thanks my brother for your reply.
For the first paragraph, please i need some explanation.
as you'll see on the Switch configrations, the Inter gig 8/25 on switch is the port that connected to DSL router.
i'll check it now
Sorry, it's not working totally , the DSL router 877 dosen't support the trunk mode
Dear Brother Vijay,
It's working with me now, yes it was a NAT issue.
Thanks for your support, it was very useful for me.
Thanks again.
-Mohamed
