internet connection
carl_townshend
Hi,all , we have 2 connections to the internet at my place of work, 1 is used for failover, Would it be possible to multilink these 2 connections whilst still providing redundancy ?
spremkumar
Level 11
Level 11
Hi Carl
If its from the same service provider you can do that but for failover i dont think the customer might have gone with the same SP where hes having the primary circuit.
Also what kinda media you are using up over there ?
regds
