Internet Traffic Not Routing Through VPN 891w
reese.steven
Level 4
Level 4
Ok, here's the situation. I have an 891w as my edge device for my home office. I have a VLAN for family use (wired and wireless) that routes out to the internet just fine. I have a second VLAN assigned to a VPN tunnel that backhauls traffic to my corporate network (wired and wireless) and all of the traffic gets to the corporate network fine when I am on that VLAN.
However, while I am on the VPN VLAN, no traffic gets to the internet. I believe it is because I have the gateway of last resort (0.0.0.0) set to the WAN IP address provided by my ISP, so DNS is resolving against corporate, but because there is no specific route, it is trying to dump the traffic back out the WAN without traversing the VPN tunnel.
Anyone know how I can fix that?
Thanks in advance.
jawad-mukhtar
Level 4
Level 4
Can You Post Your Config
Jawad
service password-encryption
hostname *****
boot-start-marker
boot system flash c890-universalk9-mz.152-4.M2.bin
boot-end-marker
enable secret 4 *****
no aaa new-model
clock timezone PCTime -8 0
service-module wlan-ap 0 bootimage autonomous
crypto pki trustpoint TP-self-signed-959396971
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-959396971
revocation-check none
rsakeypair TP-self-signed-959396971
ip cef
ip port-map user-DTV1 port tcp from 27178 to 27179  description DTV1
ip dhcp excluded-address 192.168.58.1 192.168.58.150
ip dhcp excluded-address 192.168.58.201 192.168.58.254
ip dhcp excluded-address 10.28.228.1 10.28.228.2
ip dhcp pool ccp-pool
import all
network 192.168.58.0 255.255.255.0
default-router 192.168.58.1
dns-server 4.2.2.1 4.2.2.2
lease 2
ip dhcp pool router-vlan228-********
network 10.28.228.16 255.255.255.240
option 150 ip 10.28.8.219 10.160.136.201
dns-server 10.28.8.137 10.28.8.138
domain-name ********.corp
default-router 10.28.228.17
ip name-server 4.2.2.1
ip name-server 4.2.2.2
ip inspect log drop-pkt
no ipv6 cef
parameter-map type inspect global
log dropped-packets enable
license udi pid CISCO891W-AGN-A-K9 sn FTX13338104
archive
log config
  hidekeys
username router privilege 15 secret 5 *****
redundancy
class-map type inspect match-any SDM_BOOTPC
match access-group name SDM_BOOTPC
class-map type inspect match-all sdm-cls-VPNOutsideToInside-1
match access-group 102
class-map type inspect match-any SDM_AH
match access-group name SDM_AH
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-any sdm-cls-bootps
match protocol bootps
class-map type inspect match-any All-SVC
match protocol tcp
match protocol udp
match protocol icmp
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any SDM_ESP
match access-group name SDM_ESP
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
class-map type inspect match-any ccp-cls-insp-traffic
match protocol pptp
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-any TMS
match protocol http
class-map type inspect match-all SDM_GRE
match access-group name SDM_GRE
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect match-all ccp-protocol-icmp
match protocol icmp
class-map type inspect match-any DTV1
match protocol user-DTV1
class-map type inspect match-all ccp-protocol-http
match protocol http
class-map type inspect match-any SDM_DHCP_CLIENT_PT
match class-map SDM_BOOTPC
class-map type inspect match-any CCP_PPTP
match class-map SDM_GRE
class-map type inspect match-all ccp-cls--1
match class-map All-SVC
match access-group name PresNet
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any VPN-allow
match class-map ccp-protocol-icmp
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-cls-ccp-permit-1
match class-map DTV1
match access-group name LVGRMDTV
class-map type inspect match-any SDM_VPN_TRAFFIC
match protocol isakmp
match protocol ipsec-msft
match class-map SDM_AH
match class-map SDM_ESP
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-all SDM_VPN_PT
match access-group 101
match class-map SDM_VPN_TRAFFIC
policy-map type inspect ccp-policy-ccp-cls--1
class type inspect ccp-cls--1
  pass
class class-default
  drop
policy-map type inspect ccp-pol-outToIn
class type inspect CCP_PPTP
  pass
class type inspect sdm-cls-VPNOutsideToInside-1
  pass
class class-default
  drop log
policy-map type inspect ccp-inspect
  pass
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-insp-traffic
  inspect
class type inspect ccp-sip-inspect
  inspect
class type inspect ccp-h323-inspect
  inspect
class type inspect ccp-h323annexe-inspect
  inspect
class type inspect ccp-h225ras-inspect
  inspect
class type inspect ccp-h323nxg-inspect
  inspect
class type inspect ccp-skinny-inspect
  inspect
class type inspect ccp-protocol-icmp
  pass
class class-default
  drop
policy-map type inspect ccp-permit
class type inspect SDM_VPN_PT
  pass
class type inspect ccp-cls-ccp-permit-1
  pass
class type inspect SDM_DHCP_CLIENT_PT
  pass
  pass
  inspect
  inspect
  inspect
  inspect
  inspect
  inspect
class class-default
  drop
policy-map type inspect ccp-permit-icmpreply
class type inspect sdm-cls-bootps
  pass
  inspect
  inspect
  inspect
  inspect
  inspect
  inspect
class type inspect ccp-icmp-access
  pass
class class-default
  pass
zone security in-zone
zone security out-zone
zone-pair security ccp-zp-out-self source out-zone destination self
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-zone-To-in-zone source out-zone destination in-zone
service-policy type inspect ccp-pol-outToIn
zone-pair security ccp-zp-self-out source self destination out-zone
csdb tcp synwait-time 30
csdb tcp idle-time 3600
csdb tcp finwait-time 5
csdb tcp reassembly max-memory 1024
csdb tcp reassembly max-queue-length 16
csdb udp idle-time 30
csdb icmp idle-time 10
csdb session max-session 65535
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp peer address xxx.xxx.xxx.xxx
set aggressive-mode password *****
set aggressive-mode client-endpoint user-fqdn *****
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
mode transport
crypto ipsec transform-set ESP-AES-256-SHA esp-aes 256 esp-sha-hmac
mode tunnel
crypto ipsec profile CiscoCP_Profile1
set transform-set ESP-3DES-SHA
crypto map ********VPN 10 ipsec-isakmp
set peer xxx.xxx.xxx.xxx
set transform-set ESP-AES-256-SHA
match address ********_CRYPTO
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
switchport access vlan 228
no ip address
spanning-tree portfast
interface FastEthernet3
no ip address
interface FastEthernet4
no ip address
interface FastEthernet5
no ip address
interface FastEthernet6
no ip address
interface FastEthernet7
no ip address
interface FastEthernet8
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0
description $FW_OUTSIDE$$ETH-WAN$
ip address dhcp client-id GigabitEthernet0
ip nbar protocol-discovery
ip flow egress
ip nat outside
ip virtual-reassembly in
zone-member security out-zone
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
no ip address
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 1$$FW_INSIDE$
ip address 192.168.58.1 255.255.255.0
ip nat inside
zone-member security in-zone
ip tcp adjust-mss 1452
interface Vlan228
ip address 10.28.228.17 255.255.255.240
interface Async1
no ip address
encapsulation slip
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source static tcp 192.168.58.102 27177 interface GigabitEthernet0 27177
ip nat inside source static tcp 192.168.58.102 27178 interface GigabitEthernet0 27178
ip nat inside source list NONAT interface GigabitEthernet0 overload
ip access-list extended LVGRMDTV
remark CCP_ACL Category=128
permit ip any host xxx.xxx.xxx.xxx
ip access-list extended NONAT
deny   ip 10.28.228.16 0.0.0.15 10.0.0.0 0.255.255.255
deny   ip 10.28.228.16 0.0.0.15 10.160.0.0 0.0.255.255
deny   ip 10.28.228.16 0.0.0.15 172.18.0.0 0.1.255.255
deny   ip 10.28.228.16 0.0.0.15 172.20.0.0 0.1.255.255
deny   ip 10.28.228.16 0.0.0.15 172.30.0.0 0.0.255.255
permit ip 192.168.58.0 0.0.0.255 any
ip access-list extended ********_CRYPTO
permit ip 10.28.228.16 0.0.0.15 10.0.0.0 0.255.255.255
permit ip 10.28.228.16 0.0.0.15 10.160.0.0 0.0.255.255
permit ip 10.28.228.16 0.0.0.15 172.18.0.0 0.1.255.255
permit ip 10.28.228.16 0.0.0.15 172.20.0.0 0.1.255.255
permit ip 10.28.228.16 0.0.0.15 172.30.0.0 0.0.255.255
ip access-list extended SDM_AH
permit ahp any any
ip access-list extended SDM_BOOTPC
remark CCP_ACL Category=0
permit udp any any eq bootpc
ip access-list extended SDM_ESP
permit esp any any
ip access-list extended SDM_GRE
permit gre any any
ip sla auto discovery
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.58.0 0.0.0.255
access-list 23 remark CCP_ACL Category=17
access-list 23 permit 192.168.58.0 0.0.0.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 101 remark CCP_ACL Category=128
access-list 101 permit ip host 207.30.28.227 any
access-list 102 remark CCP_ACL Category=0
access-list 102 permit ip 10.0.0.0 0.255.255.255 10.28.228.16 0.0.0.15
access-list 102 permit ip 172.18.0.0 0.1.255.255 10.28.228.16 0.0.0.15
access-list 102 permit ip 172.20.0.0 0.1.255.255 10.28.228.16 0.0.0.15
access-list 102 permit ip 172.30.0.0 0.0.255.255 10.28.228.16 0.0.0.15
access-list 102 permit ip 10.28.228.16 0.0.0.15 10.0.0.0 0.255.255.255
access-list 102 permit ip 10.28.228.16 0.0.0.15 172.18.0.0 0.1.255.255
access-list 102 permit ip 10.28.228.16 0.0.0.15 172.20.0.0 0.1.255.255
access-list 102 permit ip 10.28.228.16 0.0.0.15 172.30.0.0 0.0.255.255
no cdp run
control-plane
mgcp profile default
So I would say that the vlan with the issue would be VLAN 228:
If I understood the issue correctly then here is the first step to fix this:
Ip access-list NONAT
permit ip 10.28.228.16 0.0.0.15 any
Give it a try, and let me know
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Thanks for the suggestion, however that didn't resolve the issue. What I need to have happen is that any device residing on VLAN228 needs to forward internet requests across the VPN tunnel. Right now, when the request hits the router, the router is trying to send the traffic out the local WAN interface rather than forwarding it to the next hop on the VPN tunnel. That is what I believe is the issue.
