Throughput(Mpps) & Switching Capacity(Gbps) relation
Telnet-1-2
For  Cisco Catalyst 2960S-24PD-L  ,
Throughput is  65.5 Mpps  &  Capacity is  88 Gbps ... is there any raletion between both numbers ( ie from one number a calculation can lead to the other ) ?
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
No, they are independent.  However, given the a specific number of ports, and their bandwidths, you can calculate what's necessary for maximum performance.
Your particular switch has 24 gig ports and two 10g ports, so for maximum performance it needs 44 * 2 (for duplex)  = 88 Gbps for its fabric.
Minimum size Ethernet requires 1.488 Mpps per Gbps, so 44 * 1.488 = 65.472 Mpps.
Andras Dosztal
Level 3
Level 3
Check this thread, the answer is there.
