intervlan communication in 3650 switch
arupbiet2006
how i can configure like this type of vlan communication...
vlan10 communicate only vlan20 ,vla30,vlan40,vlan50 but vlan 20,vlan30,vlan40,vlan 50 not communicate each other .
8 Replies 8
mfreijser
You can achieve this by adding access-lists to each of the VLAN interfaces which define what traffic you will and won't allow through the VLAN interface.
You can find all the things you need in the Configuration Guide:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_25_se/configuration/guide/3560scg.html
Michael
hi sir,
already i had configure access list vlan10 access vlan20(ip),vlan30(ip).vlan40(ip) ,vlan50(ip)...but still it not working and also not access internet by indivisual vlan..
kindly help me how i can do this task
can you pate your config
hi sir
interface vlan not access this access-list comand
Switch(config)#interface vlan 10
Switch(config-if)#acc
Switch(config-if)#acc?
% Unrecognized command
All the information you need about the commands is in the Configuration Guide as specified above.
About your last question: Try the "ip access-group..." interface configuration command if you want to connect a access-list to a interface. playing around with the questionmark (?) will certainly help you on your way!
Michael
hi sir configure like this
If you have no idea about access lists suggest you read thru this doc .
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_tech_note09186a00800a5b9a.shtml
