intervlan communication on 6500
Wassim Aouadi
Level 4
Level 4
I have a 2 6509 VSS system. I created vlans 25 and 15. I can not ping from SVI 25 to SVI 15.
Here are the configs:
interface Vlan15
ip address 10.100.2.126 255.255.255.128
ip verify unicast source reachable-via rx
ip helper-address 172.16.5.28
ip helper-address 172.16.5.29
ip helper-address 172.16.5.14
no ip redirects
no ip proxy-arp
ip flow ingress
interface Vlan25
ip address 10.100.7.126 255.255.255.128
no ip redirects
no ip proxy-arp
ip flow ingress
TNSWCRCS01A2#ping
Protocol [ip]:
Target IP address: 10.100.7.126
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 10.100.2.126
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 10.100.7.126, timeout is 2 seconds:
Packet sent with a source address of 10.100.2.126
Success rate is 0 percent (0/5)
Cisco IOS Software, s72033_rp Software (s72033_rp-IPBASEK9-M), Version 12.2(33)SXI3, RELEASE SOFTWARE (fc2)
thanks.
Forum Tips: 1. Paste images inline - don't attach. 2. If you find a post helpful, please give it a thumbs up or mark it as a correct solution.
Rry to remove "ip verify unicast source reachable-via rx" command configuration from both SVI and check.
Please click on the correct answer if this answered your question.
Naidu.
9 Replies 9
johnlloyd_13
Level 9
Level 9
Make sure you've created your Layer 2 VLANs and have assigned ports to it. There should be at least one active port to put your SVI in up/up state. Lastly, enable 'ip routing' in global config.
Yes, vlans are created. SVIs are up.
Here is the vlan membership for vlan 15 and 25:
TNSWCRCS01A2#sh vlan id 25
VLAN Name                             Status    Ports
25   VLINFOAdmin                      active    Po101, Po102, Po103, Po104
                                                Po203A
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
25   enet  100025     1500  -      -      -        -    -        0      0
Remote SPAN VLAN
Disabled
Primary Secondary Type              Ports
TNSWCRCS01A2#sh vlan id 15
15   VLDG                             active    Gi1/2/46, Po101, Po102, Po103
                                                Po104, Po203A
15   enet  100015     1500  -      -      -        -    -        0      0
Remote SPAN VLAN
Disabled
Hello Wassim,
what happens if you disable uRPF?
my guess is that your issue might be related to this
Hope to help
Giuseppe
Naidu.
it works. Could you explain what this command is for?
Glad to solve your problem and thanks for your rating.
"ip verify unicast source reachable-via rx" command will only allow a packet through if the source address is on a network that is reachable via the received interface. This is very similar to how the old ip verify unicast reverse-path worked. The one caveat is that it will accept any packet that is received on any interface with equal cost routes.
Naidu.
but both SVIs are on the same switch. Therefore, the source address IS on a network reachable via the received SVI interface, isn't it?
by the way, I always rate useful posts
Hello Wassim,
this should be a known drawback of uRPF
the SVI that receives a packet with source address that of the other SVI considers the packet as spoofed
to avoid this you should invoke an extended ACL with uRPF as explained here
http://www.cisco.com/en/US/docs/ios/sec_data_plane/configuration/guide/sec_cfg_unicast_rpf_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1001323
to be noted uRPF is based on CEF and pinging between the SVIs should be process switched, however the issue is seen.
Edit:
command reference provides an option for self-ping with ip verify ... via
see
http://www.cisco.com/en/US/docs/ios/security/command/reference/sec_i3.html#wp1060730
(Optional) Allows a router to ping its own interface or interfaces.
to be noted it it not recommended to use this option
Hope to help
Giuseppe
Thanks Giuseppe for the explanation
