Intervlan comunication 5672 UP
sumanitccna
Community Member
Hi ,
I am very new to the nexus and I am going to configure a Nexus 5672 UP to B22 . I want to configure below details .
1. Create Vlan 10 , 20. 30 , 40 in such a way that Vlan 20 and Vlan 30 can communicate each other .
2. I would like to connect it to B22 as Fex .
3. How I will configure management interface .
Please help me with details ASAP
Reza Sharifi
Use the config guide (link below) to configure layer-2/3 vlans.  There isn't much of difference between Nexus and other platform when it comes to vlan configuration.
The switch has an out-of-band management port you can use to connect to another switch or you can use a vlan for in-band management.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5600/sw/interfaces/7x/b_5600_Interfaces_Config_Guide_Release_7x.html
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/configuration/nxos/Cisco_Nexus_5000_Series_NX-OS_Software_Configuration_Guide_chapter4.html#con_1110654
7 Replies 7
Reza Sharifi
i have configured the vlan but inter vlan is not communication is not happening
Do you have inter-vlan routing feature enabled?
how i will enable this feature.
What is the output of "sh license usage" and "sh license"?
S1# sh license
MDS201610130815346940.lic:
SERVER this_host ANY
VENDOR cisco
INCREMENT LAN_BASE_SERVICES_PKG cisco 1.0 permanent uncounted \
VENDOR_STRING=<LIC_SOURCE>MDS_SWIFT</LIC_SOURCE><SKU>N55-BAS1K9=</SKU> \
HOSTID=VDH=FOC2028R1UH \
NOTICE="<LicFileID>20161013081534694</LicFileID><LicLineID>1</LicLineID>
<PAK></PAK>" SIGN=13703A7ED868
license_FOC2028R1UH_3_1.lic:
VENDOR cisco
INCREMENT ENHANCED_LAYER2_PKG cisco 1.0 permanent uncounted \
VENDOR_STRING=MDS HOSTID=VDH=FOC2028R1UH \
NOTICE=<LicFileID>20160802205100000</LicFileID><LicLineID>1</LicLineID><
PAK>N5K-C5672UPFOC2028R1UH</PAK> \
SIGN=758D1A24787A
S1# sh license usage
Feature Ins Lic Status Expiry Date Comments
Count
FCOE_NPV_PKG No - Unused -
FM_SERVER_PKG No - Unused -
ENTERPRISE_PKG No - Unused -
FC_FEATURES_PKG No - In use Grace 116D 13H
VMFEX_FEATURE_PKG No - Unused -
ENHANCED_LAYER2_PKG Yes - In use never -
NETWORK_SERVICES_PKG No - Unused -
LAN_BASE_SERVICES_PKG Yes - In use never -
LAN_ENTERPRISE_SERVICES_PKG No - Unused -
S1#
It appears that you don't have the right license
You need to purchase and install:
or
