intervlan configuration
fb_webuser
Level 6
Level 6
the intervlan connection i need configuration for stp, yes or no..Kindly help me... then list all the codes..thank you.. from phil aics joey cagujas
Posted by WebUser Cagujas Joey
cadet alain
if you want to communicate between two vlans then you need a L3 device like a router on a stick or use a multilayer switch and do intervlan routing with SVIs but STP has got nothing to do with it.
STP is for alleviating L2 loops in a L2 network by blocking some ports and forwarding on others.
In STP what you can configure is which switch will be the root bridge and which ports will be forwarding and blocking by manipulating link costs or port priority.
tell us what you want exactly and explain your topology so we can tell you what's best and what to configure.
Regards.
Alain.
fb_webuser
Level 6
Level 6
Cagujas, did the previous response answer your question? If yes, please respond to this comment and let us know. This will help us attribute the contributions of our community members correctly, as well as, make it easier for others to find the correct answers.
Posted by WebUser Cisco NetPro
