InterVLAN IP not ROUTING question.
fbeye
Level 4
Level 4
Hello. I am having some issues getting my InterVLAN Routing to work.
I just want any device on the 10.0.1.x to talk to/send data back and forth to 10.0.2.x and 10.0.2.x to 10.0.1.x
There is no configuration on this L3 Switch aside from this;
ip routing
interface vlan 12
ip address 10.0.1.115 255.255.255.0
no shut
interface vlan 13
ip address 10.0.2.115 255.255.255.0
no shut
interface gigabitethernet 1/0/21
switchport mode access
switchport access vlan 12
no shut
interface gigabitethernet 1/0/22
switchport access vlan 13
no shut
10.0.0.0/24 is subnetted, 2 subnets
C 10.0.2.0 is directly connected, Vlan13
C 10.0.1.0 is directly connected, Vlan12
balaji.bandi
Looking at the issue - On switch upgrade to stable IOS and Test, some time  IOS 12.X was too old, and maybe some default config may have some issue. the new version of code cisco offering, what is required to be the default, and what is optional to configured commands.
BB
balaji.bandi
Looking at the diagram, noit sure what is the config on the WIFI Router ?
switch config looks good.
Pc can able to ping 10.0.1.1 and 10.0.1.115 and 10.0.2.115 ?
from switch you able to ping 10.0.1.1 and 10.0.2.1 ?
BB
The WiFi Routers are a LinkSys and a D-Link
Both WiFI routers have no protection like no ping ignore, no DoS etc and both have dhcp servers.
If I recall,
10.0.1.1 Router IP Route - 10.0.2.0 255.255.255.0 10.0.1.115
10.0.2.1 Router IP Route - 10.0.1.0 255.255.255.0 10.0.2.115
The L3 Switch can ping EVERYTHING.
10.0.1.165 (PC) can ping 10.0.1.1, 10.0.1.115, 10.0.2.115 and 10.0.2.1 but nothing beyond. It doesn't even acknowledge 10.0.2.111.
I will say this.... On my very first ping from 10.0.1.165 to the NAS 10.0.2.111, I get ONE response then a timeout and cant do it again.
When I remove L3 Switch and utilize either my 5508-X or my 891f, SAME config (aside from 5508 cause it uses security level) it works flawlessly.
balaji.bandi
BB
Thank you so much! That did it. Everything is working as I had hoped for. I appreciate it.
