reset specific switch port
elshazlyccna
how can i make reset to specific switch port like (interface f0/2)
5 Replies 5
Amit Singh
shut and no shut the port.
the configuration still on the port  Even if i shut down it
conf t
default int fa 0/2
Ctrl-z
Best regards,
Milan
Bounce the port by shut and no shut  so this answer is absolutely correct!
conf t
default interface FastEthernet 0/2
it will reset the interface settings to default
