InterVlan noob problem help
WIZARD1325
Level 3
Level 3
PC1-192.168.10.2
PC2- 192.168.10.3
under Vlan 10
PC3-192.168.20.3
PC4. 192.168.20.4
under Vlan 20
Router default gateway
192.168.10.1. for vlan 10
192.168.20.1 for vlan 20
I can ping 1 and 2 and 2 and 4 in the same Vlan but I cant ping across from vlan 1 to vlan 2  see attachments how i have it set up
I did input the default gateway info under ipconfig on each pc
What am i doing wrong?
thanks in advance
16 Replies 16
the link(s) between the switch and the router need to be trunks only when you use subinterfaces on the router (called router-on-a-stick), which you don't have configured. You are using the physical interfaces on the router, so the ports connecting the switch to the router need to be access ports.
Here is the correct switch and router configuration. For the sake of convenience, I have configured two DHCP pools, so if you set the PCs to DHCP, they will automatically get an IP address:
Switch
interface FastEthernet0/1
description Link to PC1
switchport access vlan 10
switchport mode access
spanning-tree portfast
interface FastEthernet0/2
description Link to PC2
interface FastEthernet0/3
description Link to PC3
switchport access vlan 20
interface FastEthernet0/4
description Link to PC4
interface FastEthernet0/5
interface FastEthernet0/6
Router
ip dhcp excluded-address 192.168.10.1
ip dhcp excluded-address 192.168.20.1
ip dhcp pool VLAN10
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
ip dhcp pool VLAN20
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
interface GigabitEthernet0/0
ip address 192.168.10.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 192.168.20.1 255.255.255.0
duplex auto
speed auto
Georg Pauwen
for the sake of clarity, I recreated the lab (see attachment). Rename the .jpg to .pkt and open in Packet Tracer Version 7.1.1.
