InterVlan Routing Across Two Metro E Circuits
informationage
I'm trying to build redundant metro e links from two providers. Both links terminate into two 4507 switches on each end.
Link A is in production, Link B needs to be a standby only if A fails. The two different providers have given different Vlan IDs to tag my traffic for transport through their network. The Diagram is like so:
4507_1 4507_2
LinkA Vlan 400 LinkA
LinkB Vlan 500 LinkB
My local network faces 4507_1 as default GW, which faces the 4507_2 as its GW, which faces our internet routers (7204s).
Currently everything is statically routed, and I've had a suggestion to use EIGRP, but I have no idea how to implement this using inter-vlan routing. I'd prefer to keep it simple using object tracking, or GLBP, but again, having the two different Vlans that connect together has thrown me for a loop. If I have two routable SVI interfaces, how do I setup that up on the Clients, or use that for failover?
Thanks for any input!
owillins
Level 6
Level 6
You may also consider the Enhanced Interior Gateway Routing Protocol (EIGRP) Stub Routing feature. This feature improves network stability, reduces resource utilization, and simplifies stub router configuration.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1829/products_feature_guide09186a0080087026.html
