InterVlan Routing and LAN WAN Routing in a single Router
anish_naw
Is it possible two configure Inter VLAN Routing ( Router on a Stick ) and LAN WAN Routing in a single Router.
Pls Help
Anish N
18 Replies 18
Anish
Try changing "ip unnumbered gi0/0" under your serial interfaces to "ip unnumbered gi0/0.1"
Jon
Thanks jon,
It is not possible for me to make changes in the router as the office is closed. I will make the changes tomorrow morning, and let you know the result.
Anish
Dear Jon,
Thanks for your kind support.
Sorry, I have to leave now, as the office is closed now, Can you pls post the timing of your availability for tomorrow.
Thank you once again for your kind support.
Anish
I would like to suggest why dnot u use u r 3750 for intervlan routing.
From where u r trying to get in to the router.?
If from any port on the switch check the config of the switch and ur default-gateway should be sub-interface of the router.
Mahmood
