intervlan routing behind ASA
Bart Kersten
Im setting up this lab and ran into an issue. My setup is as folows:
Internet ----> Asa ----> 3550 ---> vlans
The ASA is directly connected to the internet. The fa0/1 on the ASA is connected to the 3550 fa0/1. I configured that fa0/1 on the 3550 as a routed port. Configured the ASA as default gateway on the switch. I can ping the asa from the switch and the switch from the ASA.
However if i try to ping a host on the internet from the switch it fails.
This isnt a NAT issue because hosts on the same subnet can ping hosts on the internet.
Ive done this before with a normal router and it worked like a charm. Setting up SVIs on the 3550 and a layer 3 uplink to the gateway.
Did is miss something!? Any help is appreciated!
Thanks in advance.
Kind regards,
Bart
15 Replies 15
Bart
Glad to hear it's working, thanks for the rating.
Just one of those things i guess.
Jon
