InterVLAN Routing, cant ping
pgkool001
Community Member
Hello all!
I am new to cisco IOS and am trying to setup some basic inter vlan routing. I am unable to ping from one vlan to the other. I just recently purchased a 3750 switch and think i'v got it all setup right. Can someone help?
I have the default vlan 1 setup as ip 192.168.1.0/24 and vlan 3 setup as ip 192.168.3.0/24. The two can not ping each other.
vlan 1 is connected to a consumer router (netgear) which is connected to the internet, and I want vlan 3 to be able to access the internet.
3750switch#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.1.1 to network 0.0.0.0
C    192.168.1.0/24 is directly connected, Vlan1
C    192.168.3.0/24 is directly connected, Vlan3
S*   0.0.0.0/0 [1/0] via 192.168.1.1
3750switch#show vlan brief
VLAN Name                             Status    Ports
1    default                          active    Gi1/0/1, Gi1/0/2, Gi1/0/3
                                                Gi1/0/4, Gi1/0/6, Gi1/0/7
                                                Gi1/0/8, Gi1/0/9, Gi1/0/10
                                                Gi1/0/11, Gi1/0/12, Gi1/0/13
                                                Gi1/0/14, Gi1/0/16, Gi1/0/17
                                                Gi1/0/18, Gi1/0/19, Gi1/0/20
                                                Gi1/0/21, Gi1/0/22, Gi1/0/23
                                                Gi1/0/24, Gi1/0/25, Gi1/0/26
                                                Gi1/0/27, Gi1/0/28
2    work                             act/lshut
3    garage                           active    Gi1/0/5, Gi1/0/15
10   home                             act/lshut
11   rooms                            act/lshut
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
3750switch#show running-config
Building configuration...
Current configuration : 3903 bytes
version 12.2
<--OUTPUT SUPPRESSED-->
hostname 3750switch
boot-start-marker
boot-end-marker
<-- OUTPUT SUPPRESSED -->
no aaa new-model
clock timezone UTC -5
clock summer-time UTC recurring
switch 1 provision ws-c3750g-24ts
system mtu routing 1500
shutdown vlan 2
shutdown vlan 10
shutdown vlan 11
ip routing
ip dhcp excluded-address 192.168.3.3 192.168.3.254
ip dhcp pool vlan3
   network 192.168.3.0 255.255.255.0
   default-router 192.168.3.1
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
 switchport access vlan 3
 switchport mode access
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
 ip address 192.168.1.250 255.255.255.0
interface Vlan2
 ip address 192.168.2.1 255.255.255.0
interface Vlan3
 ip address 192.168.3.1 255.255.255.0
interface Vlan10
 ip address 192.168.10.1 255.255.255.0
interface Vlan11
 ip address 192.168.11.1 255.255.255.0
ip default-gateway 192.168.1.1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip http server
ip http secure-server
end
Thanks in advanced
P
please close this as getting answers  on
VLANs not routing to eachother - 3750 post
